Question about SanDisk Sansa m250 MP3 Player
Sansa m250 playlists
I can create playlists via Quintessential Player. I drag them and mp3 files to Sansa m250. Start M250, select the playlist I want, press play and get "no files". Have also tried "send to' feature on Quint player. Tried 'send to' for Playlist and Mp3 files to Sansa but still get 'no files' when trying to play the list.
Am trying to create playlists on Sansa w/o learning or fighting Win Media Player.
Have three items that appear on Sansa. Using Explorer
Sansa m250 (E)
Folder - AUDIBLE
Folder - RECORD
Should have other folders? Place Playlist in separate folder? Cannot do drag and drop? Need to get another music player?
Appreciate it. Jamie
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Posted on Oct 22, 2008
My playlists from sansa m250 disappeared but when i connected ..
When transfering the songs from computer to player. First, sync device before transfering. Only do this the very first time. If you try to sync with songs already on the player, they will be erased.
To test the device. Open your comuters music file folder, keep folder open, than go to start menu, go to my computer and open the folder (D: or F: folder) It will have your player listed there.
Now with both folders open, take a song from the music folder, drag it to the sansa folder and drop it in there. It should be added to player.
May 05, 2009 | SanDisk Sansa m250 MP3 Player
How do you create a playlist?
Solution 1 In the Sansa drive in Windows Explorer select the songs that you want in the playlist. Right click and create playlist. You can do minimal playlist editing through the playlist file properties. Drag files to the references tab to add files.
There is a free playlist creator which creates playlists for each folder on the sansa player with one click. it is written in .NET and does not alter the music files (http://www.infosys.tuwien.ac.at/staff/cp/playlist_creator.zip).
There is also one written in Python that should work on both linux and Windows (http://people.ifm.liu.se/yohell/make_playlists.py).
Solution 2 Try Musicmatch Jukebox or MediaMonkey. Both of those should be able to create a music library using only files from the device. Then sort them by artist and album, and delete them from the library, deleting the files as well. Transfer new files to the device as files (MSC USB mode on the player), not by syncing. You can create a new music library on the fly if you've made extensive changes. It doesn't take much time. Playlists should not contain drive letters or folder names, so edit them in Notepad, unless you have an app that makes them on the fly (suggestions?).
You can keep your main database in MediaMonkey, and open the Sansa device (see the plus and click on it). You'll be able to delete files from there. But if you double click on a song on the Sansa device, the wrong song will play. Dunno why, but that's what happens on my computer. But deleting files works.
Solution 3 Rename all your tracks so artist (look for batch renaming feature in your software. Add example of freeware editor?), album and song name is in the file name. That won't be visible in the player, but can aid administration if you use the player in MSC mode.
Solution 4 A how-to for using Windows Media Player and syncing to make playlists can be found here.
added by thatsRich 04-08-06 - I was having trouble sorting on my Sansa m250 using drag and drop with basic file management for mp3s. After seeing this article, I tried Windows Media Player (version 10) and found that perfect for the job. Since you can drag mis-sorted files in the left pane, they "sync" in proper order.
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
M250 does not recognize some songs in the playlist
Use Windows Media Player to do this, not winamp
Nov 03, 2007 | SanDisk Sansa m250 MP3 Player
How to create multiple playslists for M250
Alright, well if you are adding songs to your MP3 player by using Windows Media Player, you can create playlists there, sort the songs into what playlists you want them in, right click the playlist, and click "add to sync list".
If you are manually copying and pasting the music into the mp3 player (that's how I do it) it's a little less obvious... For me there are three main folders: Music, Playlists, and RECORD. So we want to go to the playlists folder. In there, assuming you have at least one playlist already, you can copy and paste it, naming it something else and changing its properties as you see fit (right click -> properties). To add songs to the playlist, you go to it's properties, and under the references tab, drag the music files from wherever you have them stored and drop them in the references tab. This won't move your music, it'll just add them to the playlist. and.... guess that's about it. Hopefully that helped.
Feb 24, 2007 | SanDisk Sansa m250 MP3 Player
Can't create or play 'playlists'
Create your playlist with winamp and then copy it over with the songs listed in the playlist. You can make as many playlists as you like and they will show up under "playlist" on the screen
Jan 20, 2007 | SanDisk Sansa m250 MP3 Player
Can't sync file
Try formatting your unit and reinstall your playlist it will work.
Jun 21, 2006 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
256 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
