Question about Polaroid FLM-323B Television
Picture won't come in clear until TV "warms up" for 15 minutes or more
Help!!! Our TV picture doesn't come in clearly until the TV has "warmed up" or been on for at least 15 minutes or more. It has lines that seem to almost "roll" on the screen or it seems like a really shaky picture and the sound doesn't come in right until the TV is warmed up. What could be the cause of this and how can we fix it? It is driving us crazy. We should be able to turn the TV and the satellite on and have a clear picture right away. Thanks for any assistance.
  • Anonymous Mar 23, 2014
    when the tv comes on it does not say bravia and there is no picture and only sound until it warms up for at least an hour
  • 4 Answers
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Nov 13, 2008
LG flatron l1915s monitor, green led flashing only when coming out of standby resulting in no picture
Check the electrolytic capacitors inside in the power supply board portion. replace all busted ones.
Jan 10, 2014 | LG L1915S 19" LCD Monitor
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
Nov 14, 2013 | Televison & Video
When tv is turned on it takes 35 minutes for the pitcure to come on, like it is warming up. It is a flat screen digital tv and only 3 years old.
u have to replace apart inside the tv (picture tube base)
which connects picture tube to circuit board,,, call aservice pro...the symptoms are blurry picture & after some time picture gets clear
Apr 02, 2010 | Bush 5693D 24" TV
My CRT TV displays a single horizontal white line across the screen. It will flicker and try to display the picture. If you smack it you'll get a quick picture then back to a line. After about 10-15...
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Dec 21, 2009 | Toshiba 32A33 32" TV
Picture blinks for about 4 minutes then comes into clear picture
Is the flashing get more rapid as the set warms up and even once its on is the picture somewhat out of focus around the corners? If the answer is yes then your picture tube is showing signs of age. The older they get the lower the emissions are. The replacement picture tube part number 8-735-048-15 is showing a cost of 741.45 from the following web site. Please take a few moments to rate my answer. Thanks...
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5720885
Nov 21, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Mar 07, 2009 | LG 42PC3D 42 in. Plasma Television
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Polaroid FLM-323B Television Logo
584 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
