Question about HP iPAQ RX3715 Pocket PC
Battery Problem It seems that my iPAQ ran out of battery/charge and turned off. When I put it back into the cradle to charge it, it still wouldn't turn back on. Does it need to wait until its fully charged to turn back on, or do I have a bigger problem? Thank you!
  • Tals10 Mar 06, 2008
    The battery charges and works fine in my husband's iPAQ. The charger charges his phone- it just seems to be personal....
    Problem Solver:
  • 15 Answers
Unfortunately, I think you have a bigger problem.
Ideas:
1. In the interest of not costing you extra money, wait a few days to see if anyone has any last-ditch ideas.
2. Your battery is probably completely dead. Try purchasing a new one (Amazon.com is good).
DO NOT THROW AWAY THE OLD BATTERY!!! If the new battery still does not work, the old one has probably been shorted by the charger, but it might not have been, and you will now have two working batteries.
3. If that doesn't work, then like I said, you probably have a short in your charger. Refer to
http://www.fixya.com/support/t395532-not_turn
For the solution.
You can try these solutions in either order, but this is the order i suggest.
Happy fixing!
Posted on Mar 01, 2008
SOURCE:
My Samsung behold ran out of battery this morning and it was dead for an hour or two. After I plugged it in to charge for a couple minutes, it still wouldn't turn on. After several attempts of taking...
Sounds like a battery problem. Seems your battery is completely dead. Get your cellular provider to order you a new battery. That should fix your problem.
Jul 06, 2011 | Samsung Behold Cell Phone
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your iPAQ in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Hp ipaq seems dead
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Compaq Ipaq not Charging
As I understand it, the basic cradle that comes with the Compaq Ipaq 3870 does not charge. If I were you, I'd either seek out a charging cradle or google the instructions for modifying your cradle to charge. Good luck...
Dec 02, 2008 | Compaq iPAQ H3760 Pocket PC
Ipaq H3835 PDA - won't hold charge??
If you purchase a new battery, they usually come with directions and special tools to change the battery. I had the same issue with 2 of mine when I got them at a used electronics store. IF it is the battery that is not working, then replacing it is easy, and you can get a replacement at your local Battery-Plus store.
In my case, one was fixed by a new battery, the other was not, and I actually had to press pretty hard in the cradle to get the second one to work. It never worked out of the cradle, so I gave that one to a neighbor kid to tear apart and see if he could get it working. (I got them for $15, so no big loss.)
Apr 21, 2008 | HP iPAQ H3835 Pocket PC
H6315
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
Ipaq unresponsive
That's a very odd scenario. Have you tried putting it on the cradle without the battery? One possibility is that it was an incorrect battery that you put into it and it somehow fried the PDA. That's however very unlikely. Have you tried putting your old battery in it?
Nov 16, 2007 | HP iPAQ H3635 Pocket PC
HP Ipaq 4155 not recognizing battery
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Nov 07, 2007 | HP FA162A for iPAQ 2215/4155 Keyboard
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
82 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
