Question about Photography
Nikon F3 rewind knob
I need a rewind knob and crank for a nikon F3...... where can i find one?
Richard LaMarre
Nikon usa still provides parts for Nikon f3 cameras. You can order by phone at : 310-414-8107. They are very helpful and take great care of Nikon owners,
Posted on Jan 09, 2009
I have a Nikon FM3 and the shutter opens at the correct speeds but when I put B&W film in it (Kodak TX 400) and develope the film, there is nothing on the film like it was brand new. Help please.
Check to make sure that the film is properly inserted into the take-up spool, and watch the rewind knob and make sure it is turning indicating that the film is going through the camera. Also check to make sure that the multi-exposure lever isn't stuck in the on position by spillage or impact so the camera just keeps taking exposure on one frame and the film doesn't move.
Sep 29, 2012 | Nikon F3 35mm Film Camera
Removing Nikon FM2N top plate
Unscrew the rewind knob and remove a circlip under it (You may need to grind the tips of a pair of round-nose pliers for this). Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Do not remove the center screw from the shutter speed dial. Remove three screws from the side of the dial and pull off the grip ring.
Jul 08, 2010 | Nikon Photography
I can't open the camera back on my Nikon FM3A 35mm SLR Camera. Is it because of the poor battery level?
The battery does not affect the back cover opening.
The back can be opened by lifting up on the film rewind knob but on this model, there is a lock. Lift the rewind knob and at the base of the rewind knob is lifted from, there is a safety lock. You have to move this safety lock and lift the film rewind knob at the same time to open back.
http://tinyurl.com/2u7wtt
has the instructions.
Jun 28, 2010 | Nikon FM3A 35mm SLR Camera
How to open fim back door ?
While pushing the lock around the rewind knob counterclockwise with a finger, pull up on the film rewind knob until it clicks. Then pull up a little further until the back pops open.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 21, 2010 | Nikon FE 35mm SLR Camera
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
I cant open the camara take off the film inside
After rewinding the film, nudge the little switch between the ISO dial and the rewind crank counterclockwise and lift up on the rewind knob until it catches. Then pull up a bit more and the back should spring open.
Dec 27, 2009 | Nikon FE 35mm SLR Camera
Film rewind crank stuck in up position nikon n2000
Move it a bit (some half circle)back and forth. The slot may be in wrong position related to the roll inside. It should click in when you get the slot in right angle.
Aug 02, 2009 | Nikon EM 35mm SLR Camera
Can't find manual for instructions Nikon N55
If you want to rewind manually, you need to press two buttons simultanously. Turn the power on. First, hold "BKT" button just above lens release knob then press the button "+/1" just next to the shutter release. Both button will have red rewind sign next to them. -James
Apr 05, 2009 | Nikon N55 35mm SLR Camera
I dont know how to load my Nikon 35mm camera. I need instructions
Pull up the film rewind knob to open the back.
Drop the cartridge into the well on the left and, while rotating the rewind knob, push it back down to secure the cartridge.
Pull the leader across and insert it into any of the slots in the takeup spool.
Make sure the film perforations engage the sprocket teeth.
Alternately wind the film lever and press the shutter button until the perforations on both edges of the film engage the sprocket teeth.
Close the camera back, making sure it latches.
Take up the film slack by rotating the rewind knob in the direction of the arrow until you feel resistance.
Make blank exposures until the counter shows "1".
There's a fuller, illustrated set of instructions in the manual, which you can download from http://www.butkus.org/chinon/nikon.htm
Mar 20, 2009 | Nikon FG 35mm SLR Camera
Nikon fa how do i start ? how do i get the film out i need the basics
On all of that series of Nikon SLRs, there is a small black plastic tab under the rewind handle on the left side of the camera. (as looking from the back). The tab needs to be pushed lightly and that will release the rewind shaft so you can pull up on the rewind knob to open the film door.
more info can be found here on Fixya
The FE2/FM2 are very similar in operations and function
May 29, 2008 | Nikon Cameras
Photography Logo
191 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
