Question about Panasonic Home Theater System System
Panasonic SA-HT 955 Home Theatre System
Hi;
I having error F61 on display. What problem it could be causing this message?
Our building was bashed by storm recently. I have open the unit and replaced rectifier and IC STR F6668. It started to work with few dashes and after that F61 appeared.
Thank you
Regards Juraj
  • pjuraj Sep 01, 2008
    Hello Dan,
    Thank You for your assistance. However, the output stage IC's were not the issue. Even though, I replaced them with new ones, I still had the same problem.
    Once, I solve the problem, I will forward to you the information for your knowledge.
    Regards
    Juraj
  • pjuraj Sep 04, 2008
    Hi Dan,
    I have found another faulty IC2301(4 channel switch). It was dropping symmetrical voltage from 7to 4 volts because I don't have a replacement & I just soldered it away. I was hoping the error message would not appear.
    Could that switch be causing the error message? I can forwarded to you the schematic diagram. How can I forwarded it to you?
    Regards Juraj
  • 4,234 Answers
The F61 is the shorthand for protect mode. This indicates a problem with the output amplifier section. I don't have a listing for your specific model, but a similar one HT95 lists IC501 as the output amp chip. Check for the marking on the large black IC attached to the heatsink it may be RSN311W. If so, this can be ordered using part number: RSN311W64D-P for $95.20 from tritronicsinc.com.
Hope this helps,
Dan
Posted on Aug 28, 2008
  • ABRsvcs Sep 03, 2008
    There is a regulator chip inside these that can cause the same symptom. While rare, this occurs as well. It mimics the amp problem because some of the voltages are not there to enable the output amp to work properly. I don't have the manual with me at the moment, but this chip should be a multi-pin one attached to another heat sink. Look around at all of the chips to be sure of solid connections as well. Resolder any that appear to be grainy or have rings. Keep me updated. I'll look up the remaining possibilities in the meantime.
    Dan
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
My panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Jul 13, 2009 | Audio Players & Recorders
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
F61 Error then the system goes dead
The battery might have broken so you might want to try buying a new one or charge it up fully.
Dec 01, 2008 | Panasonic Home Theater System System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Jan 10, 2008 | Panasonic sa-ht800V Home Theater Audio...
Panasonic Home Theater System System Logo
478 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
