Question about Samsung CLP-510 Laser Printer
How to install this driver in linux pc and how it store it in its drives
  • Roberta Smith
    Roberta Smith May 11, 2010
    What version of linux ?
    Problem Solver:
  • 5 Answers
Download unified linux driver from this page.
Follow the related installation instructions:
1. Make sure that you connect your machine to your computer. Turn both the computer and the machine on.
2. When the Administrator Login window appears, type in root in the Login field and enter the system password.
3. Download and extract the driver
[root@localhost root]#tar xzf [Downloaded File Name(XXXX.tar.gz)]
4. The driver will be extracted as ''cdroot'' folder in current path.
5. Execute installation program.
[root@localhost root]#./cdroot/autorun
6. When the welcome screen appears, click ''Next'' and proceed installation.
Posted on Aug 30, 2009
Laptop random shutdown: Safe-mode; Linux
Did u dual install Linux and 7 on 2 different Partitioned Drives?
Is it only linux with the problem or is windows playing up to?
possible a bad install of linux as a OS?
Try uninstalling linux (leave windows) and partition the hardrive (making 2 different drives i.e. C and D on a single Physical Hard Drive -- its just divided into 2 parts)
and try running Linux from a single clean hard drive and leaving Windows seperate.
that MIGHT solve ur problem. gl.
Mar 17, 2014 | Computers & Internet
Toshiba MK30186A
Don't think CrunchBang Linux support SATA hard drives. Try setting mode to IDE/Legacy, might work.
Jun 07, 2012 | IBM Computers & Internet
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
HP Slimline s3500f, Vista 64-bit. CD/DVD stopped working. I've reloaded the driver several times. Device manager says it is working properly. I have removed upper and lower filters in registry, I have...
A couple of suggestions.
1) Download HP Support Assistant to check for updates on your machine
2) I assume you are using Windows Media Player. Try another free program like VLC. Its handy to have 2 installed so you can toggle between the 2 if one is having problems.
Sep 18, 2017 | HP Pavilion Slimline s3500f Desktop...
Pc chips a33g no boot windows
If you have a SATA hard drive your windows disk needs SATA drivers on it.
Download Driverspack from this site
Mass storage one
then copy windows CD to hard drive and use "Nlite" to install driverpack into it then burn windows to new CD and try again.
This should solve your problem
Dec 27, 2008 | PC Chips A33G (V1.0) Motherboard
Hp compaq cq 40 108 tu laptop can i get audio video drive
can i get solution to install win xp on compaq cq 40-108
Dec 09, 2008 | Compaq Presario Notebook
Compaq presario v3611 AU - redhat linux driver
all linux drivers may be obtained here,|1424739981 RICHARDM69
Oct 09, 2008 | Compaq Armada 3500 Notebook
My sata hard hard drive is not detected in linux
Check in your BIOS settings that SATA drives can be seen as "ATA"
Install Linux, and then , after everithing went OK, change BIOS to SATA again.
Aug 04, 2008 | Computers & Internet
Drivers required
SCSI Drivers are only an optional part.
This is not a problem with your driver floppies.
The problem is with the linux being preinstalled on the HD.
Linux uses many types of file-systems. Even if it was NTFS or FAT, it is most probable that windows xp cd won't be able to recognize it; because, it may use unsupported method of formatting.
What you have to do is;
1. Format the two HDs by either
  • Moving it to another windows or linux computer and fully formatting the Hard Disks using fat32 or NTFS (supported by windows). If it is a windows PC using for formatting, no problems. If it is a linux system, delete all partitions, and format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
  • By a linux installation CD and here too, format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
2. Install the windows xp in it, using the same booting from CD Porcess. Here, you may or may not choose to install the SCSI drivers ( the floppy you got by pressing F2 when it says to do so in the installation immediately). It is good not to install the SCSI drivers if it is not a necessity for you.
Now, you can create any number of partition, format, etc during win XP installation.
Feb 18, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Feb 04, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Samsung CLP-510 Laser Printer Logo
171 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
