Question about Pentax *ist D Digital Camera
On Camera Flash Problem and Lens Question
I have a problem with 2 month old *ist digital. Popping up the on camera flash kills the battery, on new batteries of several types. Putting the flash down and turning the camera on and off brings the battery back to its original full charge condition. Anybody have ideas, I have read something about this problem somewhere on the forum before. Does anyone know anything about the new Tamron XR 3.5-6.3 28/300 LD Lens, is it of high quality and resolution. It seems very light and small for its power
    Master:
  • 542 Answers
According to Pentax, the pop up flash does greatly reduce battery life. So, if you want them to last longer, use an external flash. The built-in flash is too low powered an too prone to produce red eyes to be of much use anyway. Any lens that goes from 28-300 is going to be much less sharp than one with a shorter zoom range, even if the lens designer uses such heroic measures as aspherical elements and LD glass. Consider the Tokina AT-X 24-200mm f/3.5-5.6 lens as a very good alternative to the Tamron.
Posted on Sep 08, 2005
Slave/wireless flash
As long as the camera flash is working, a slave flash will work for you. They're triggered by the light of the camera flash.
Jan 03, 2010 | Pentax *ist D Digital Camera
I fully charge the battery and recently it lasts just 2 days in the camera whether being used or not. the camera is just 5 months old. Would this be abattery or camera fault
Mine is over a year old. I typically need to charge it once a month if not in use and otherwise after about 800 shots without flash or 300 shots with flash.
Oct 26, 2009 | Canon EOS 450D Digital Camera
Flash not popping up - did i push something?
Make sure you're not shooting on no-flash auto mode. Also, in P, A, and M modes you'll have to press the flash button on the side of the camera by the lens mount in order for the flash to pop up. If it's not popping on regular auto mode, make sure you don't have it disabled in the menu.
Jun 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Flashing red hand keeps popping up, when batteries
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Jun 05, 2009 | Nikon COOLPIX L18 Digital Camera
HP Camera won't flash
HP wont get your money for another camera period- the have dropped cameras from their line up- in the UK any way.
The precise reason for the non function of the flash is not immediately fathomable - but it is likely non use ,the capacitor that triggers the flash in a full state and not having been discharged could have 'killed' it.
As with pretty well all low end digital camera s'repair' is not an option, only replace.
So off you go and buy a new one- if it is flash you need- but perhaps you can live without it.
So often you see folk using their camera swith the flash popping off when in fact non was needed.
Jan 27, 2009 | HP Photosmart R827 Digital Camera
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Pop-up flash
make sure after popping up the flash, you didn't change the mode into "no flash" mode....an easy way to check is put the flash back down, then proceed to take another photo. If the flash pops up again but did not flash, you have a faulty camera (assuming battery level is at least until the 1/3 mark).
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Problem with slr camera flash obstruction
The problem is in the flash pop up switch. It is probably jammed in or there is some kind of substance on it causing it to stick. You can find it by manually popping up your flash. You should then see a little black spring loaded post on the release button side of the flash. Check to see that it is not stuck in in any way. If so that is why you are getting error 5. To repair you can try a qtip an a little rubbing alcohol. Otherwise you will need a technician to do it.
Dec 04, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Flash won't work
Try in custom menu I think. Switch shutter release whilst charging firmware switch whilst flash charging a couple of times. Had sinilar thing with ist DS after firmware update.
Jan 08, 2007 | Pentax *ist DL Digital Camera
Pentax *ist D Digital Camera Logo
75 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Mohamed Ismail
Mohamed Ismail
Are you a Pentax Camera Expert? Answer questions, earn points and help others
