Question about Toshiba e740 Pocket PC
Fail Power Off in my PDA when this isn't connect to cradle, when only run with the battery the PDA it's ever Power On, but when connect to cradle the PDA don't fail, What can I do?
    Master:
  • 903 Answers
You should try to use the PDA with the Power Supply cable directly,without the Cradle between it, Does the PDA works ?
Posted on Sep 08, 2005
SOURCE:
Replacement new Battery In PDA not functioning
I will be writing off the PDA as it is now over three years old and updating to more recent technology. I have not yet made my repalcement choice.
Jan 28, 2010 | Palm Tungsten T3 Handheld
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
The PC is not switching on
Without know exactly what already you tried to powered it on, I can only especulate on all the possible reasons, so let go one by one throuh them and their possible solutions:
1. The RX3000 Ipaq family has a known mechanical issue on the switch that senses when the back cover lid is properly closed.
When the switch is nor properly depressed, the PDA won't charge the battery if plugged on the cradle or to the USB sync cable, or won't turn on.
Remove the back cover lid and the battery, put them back again. Check the cover lid is placed flush and that there is not any gap between the cover and the PDA body.
Try again in power it on and/or charge the battery, confirming the orange LED light is turning on.
2. Either the cradle/USB sync cable or the AC wall adapter are defective.
The PDA won't power on if the battery is not charged to the minimum voltage for it. If the AC wall adapter or the cable/Cradle are defective, won't power on.
Put to charge the battery and confirm the orange LED light is turning on. If so, the you can discard that the cradle/USB cable or AC wall adapter are defective.
It the orange LED light won't turn on, it may be either one of these three parts that are defective, or that the back cover lid is not properly closed.
3. The battery dried out. If the battery is defective or won't accept charge, the pda won't power on.
To discard a defective battery, put the PDA to charge it, and it will power on when plugged to the USB cable or to the charger, and check in the settings screen, on the power icon, if the battery is charging.
If the back cover lid is properly placed, and the PDA won't power on when plugged to the USB cable or AC wall adapter, then the battery is not the problem.
4. Discarding that the battery or the USB cable or cradle or the back cover lid are the problem for this problem, the only option that is left is that the main board is defective.
Such failure on the mainboard could be caused for several reasons (moisture or humidity or water damage, or a electronic component that is worn out, or a integrated circuit that is shorted, etc) but it can be only verified and confirmed by an electronics technician.
You have the option of send it to be repaired, or try it yourself, which will require to buy a PDA with working mainboard (or the mainboard alone) and swap the parts. It requires a minimum of technical skills to do it.
Best regards,
Feb 02, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq seems dead
Best regards,
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Won't turn on
Best regards,
Oct 27, 2008 | HP iPAQ RX3715 Pocket PC
HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Jun 30, 2008 | HP iPAQ H5550 Pocket PC
Dead!
Best regards,
Apr 22, 2008 | HP iPAQ RX3715 Pocket PC
PC/PDA "connected" yet PC won't read PDA
try syncing through bluetooth, there could be a problem with the cradle. i have had an issue very similar to yours and had to do a soft reset on my pda. then set up your device to use a blue tooth connection( you may need to buy a bluetooth dongle for your pc).
Feb 06, 2008 | Compaq iPAQ H3850 Pocket PC
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
PDA would not turn on...
try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Jul 24, 2007 | Dell Axim X51v Pocket PC
Open Questions:
GOOGLE CHROME password reset phone number +1800 828 0294 RAJAN RAJAN Get GOOGLE CHROME 1800 828 0294 password reset phone number easy steps to forgot or change GOOGLE CHROME password reset via phone number #1-************ just follow some steps to recover GOOGLE CHROME password while you want. In varoius conditions many people lost their account password and much more secure information or information may be hacked by anyone so in that case people want to configure GOOGLE CHROME with GOOGLE CHROME or other microsoft account services. Their are many certified officer to suggest people that how to change or reset GOOGLE CHROME voicemail password using phone number in easy mode wih simple procedure. Hence search engine suggest many combinations to reset GOOGLE CHROME password to reset or change it quickly, if you have any of them so contact to get well GOOGLE CHROME support form us. GOOGLE CHROME password reset not working GOOGLE CHROME password reset phone number GOOGLE CHROME password reset contact number GOOGLE CHROME password reset help GOOGLE CHROME password reset support GOOGLE CHROME password reset wont work GOOGLE CHROME password reset wont work GOOGLE CHROME password reset link GOOGLE CHROME password reset issues GOOGLE CHROME password reset usa GOOGLE CHROME password reset customer service. GOOGLE CHROME email account password reset ' free GOOGLE CHROME email password recovery ' cannot reset GOOGLE CHROME email password ' GOOGLE CHROME email password recovery ' GOOGLE CHROME email password recovery download ' GOOGLE CHROME email password recovery software ' free GOOGLE CHROME email password recovery. GOOGLE CHROME email password change, GOOGLE CHROME email hacked password changed, GOOGLE CHROME email hacked can't change password, change GOOGLE CHROME email password on iphone, change GOOGLE CHROME email password on ipad, change GOOGLE CHROME email password on android, GOOGLE CHROME email account hacked can't change password, how to change GOOGLE CHROME email password on droid, GOOGLE CHROME email password problems, GOOGLE CHROME email password not working, GOOGLE CHROME email account password reset. GOOGLE CHROME password reset phone number.
Apr 26, 2019 | Microsoft Computers & Internet
See all Toshiba e740 Pocket PC Questions
Toshiba e740 Pocket PC Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
