I want you to try something but if it does not work please let me slide on the low rates. I have seen this happen a lot when the defrost timer goes into defrost the switch is in a place on timer that causes a weak timer to stop there if timer is defective. Your timer is part number Click Here=> 67001036 You will find it inside the fresh food section and behind the control panel=> ARB220ZCS_Controls In that photo you will see a number 12 and that is the timer location. Most refrigerators will have a hole going through the control panel (with plastic plug to hide hole) so you can place a flathead screwdriver inside and slowly turn clockwise. If compressor and fans come back on just replace timer. You also may have a bad thermostat. If compressor was quickly starting and then stopping I would look for something in the compressor area. But these symptoms seem to stick out for me, Thanks Sea Breeze
