Question about Intel D845GVSR Motherboard
My pc is not running
When i turning on my pc, it required a system device. But when i inserted a formatting cd, it says that there is a problem detected. And it also says that make sure that the software or hardware is propperly installed. What will i do?
please send also youre answer here;
oliverperona2978@yaho.com.ph
  • Roberta Smith
    Roberta Smith May 11, 2010
    what was the device ?
    which formatting cd did you attempt to use ?
    and what was the problem(s) detect and when ?
    What software & hardware are you referring to ?
    Robert
My pc lan is not working?
Posted on Aug 28, 2008
How do I format a cd disk for back-up?
You should not need to format a CD disk when doing a backup, the backup software that you are using should require a blank (aka unformatted) CD to be inserted and will do any formatting necessary when writing the backup data to the CD disk(s).
Jan 01, 2012 | Microsoft Windows XP Professional for PC
How to reboot a XP4 computer
1 first insert the windows cd in cd/dvd rom 2 chek in the bios if the first boot device is the cd/dvd rom 3 vhen it boots it will say press any key to boot from cd 4 after loading all the data you must format drive C 5 after formating it will restart instaling windows you must insert the windows cd key thats all
May 16, 2011 | Microsoft Windows XP Professional
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Having corrupt files errors, tried chkdsk it states read mode only
When you run CHKDSK/F from windows, a reboot is required to scan and fix the errors as it must run in DOS or it can't work properly.
Try again or better still, format with the system file and copy CHKDSK from your windows to a USB storage device or CD and run it from there. If the device or CD is formatted as a bootable device, the notebook should boot from it in DOS and run correctly.
Hope this helps
Nov 20, 2010 | HP Computers & Internet
How do i format my laptop off of the partition on the hard drive. I've managed to hit f 10 and get into the bios but no format option was given
Formatting the hard drive is not a function of the BIOS. You will need to boot the machine from either the Windows CD and do a fresh setup (which will give you the option to format the hard drive) or boot from a bootable CD or floppy disk that has the format command on it. From there you execute the format command and follow the directions.
Jan 05, 2010 | Sony VAIO Notebook
Computers blocked
Run a repair, or better still, format the pc entering the setup with F2, while the operating system cd has already been inserted. During restart.
Sep 15, 2009 | Radware Web Server Director For...
Re-installation of windows after format C:
1. Insert the Bootable Windows CD in the CD Drive 2. Then Power On your Computer and Boot from the CD. 3. Then proceed with the installation . For installing this you dont require to find C and CD Drive. hope this solves....
Jul 24, 2009 | Computers & Internet
How do i format my drive c
Do you have the cd for either vista, xp or the operating system you intend to put on the drive, and is your pc setup to read the cd drive first? Either way insert the cd if your drive does not have a OS on it already then the cd shouls automatically run, if it already has an OS on it then you will have to boot from cd first,
turn on the pc hit delete on the keyboard a menu will pop up
use your arrow keys go to advanced BIOS features go down to where it says first boot device hit enter choose cdrom then go to the second and change that to hard drive
then hit f10 on the keyboard and the type y for yes to save then exit the screen
When the pc starts to boot up again it will show the cdrom booting up first hit any key to boot from the device will show up also tap a key on the keyboard and it will start running from the cd, follow the instructions on the screen when they come up and go from there,
Now if you are unable to get into the BIOS screen but you already have an OS on the pc then insert the cd in the pc and go to my computer and open the cd or let it automatically start up if you just inserted the cd. Then when it prompts you to choose to format.
Nov 15, 2008 | Western Digital Caviar WD2500BB 250 GB...
Format pc laptop
if you wish to do a full system factory recovery, on boot up press Alt & F10, or press F2 or Del on boot up, select the cdrom as first boot device and insert windows cd, save settings and exit for a reboot.
When prompted to press enter to boot from cd, do so and the option to repair or install will appear, choosing install will format your drive.
Sep 08, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
I have a virus called IE Antivirus - it has almost totally disabled my system. I cannot format the hd using the original Windows CD, because when I need to enter a choice via keyboard, it freezes up. I...
if you have an antivirus installed; as you should, you can run it in safe mode if required, or search for the ie antivirus folder and delete it.
You dont need the format c command if its xp, choose your cdrom as first boot device in the biossave settings and exit, and insert the cd, restart pc and press enter when prompted to boot from cd and then the option to install will be displayed
Aug 18, 2008 | Computers & Internet
Intel D845GVSR Motherboard Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
