Question about HP Officejet 5610 All-In-One InkJet Printer
Will not print
The printer will turn on, I am able to switch from copy to fax to scan ( as each option has its own button,) however if I try to print anything, lets say a document from the internet, or even a picture that I scanned -- the computer says the job is being printed, but the printer itself doesn't flinch. Then if I try and delete the job, the printer icon that shows the status says 'deleting-printer' and its stays that way no matter how many times I try and delete it. My question is why is the printer not recieving printing jobs even though the computer is apparently sending them? There is an obvious lack of communication somewhere, please help me if you can!
  • Anonymous Sep 02, 2008
    dddd
  • Anonymous Nov 27, 2008
    I cant fix it and i need it NOW NOW NOW!!! D:
  • 31 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
332
Posted on Mar 19, 2009
Same problem as above.
Posted on Nov 28, 2008
    Problem Solver:
  • 15 Answers
What you can do is disconnect the usb cable. Unplug the power cord at the back of the printer. Delete the printer icon. Make sure there are no pending documents on the queue so you could delete the icon. If you cannot delete the icon, just restart the pc. After the printer icon is completely deleted, insert the cd and add a device. It will prompt you to connect the usb cable. after the adding of device is successful, try printing a test page first before you print your document
Jiffy Epe
HP Tech Support Representative
Posted on Aug 28, 2008
It is possible to print 4 photos on one page using S305
if ur trying to print photos
there is option in photos and fax viewer right click print select 4 photos then next select printer next scroll down there is option for 4 page in one
Aug 19, 2013 | Lexmark Impact S305 Wireless All-in-One...
HP 4300 officejet fax mode to print mode
Hello etilton
Are you trying to print from a pc or do a copy?
Button 11 Fax: Places the HP All-in-One in fax mode and presents the Fax Menu. Press Fax
repeatedly to scroll through the options in the Fax Menu.
Button 12 Scan: Places the HP All-in-One in scan mode and presents the Scan To menu for
selecting a scan destination.
Button 13 Copy: Places the HP All-in-One in copy mode and presents the Copy Menu.
Press Copy repeatedly to scroll through the options in the Copy Menu.
heres the rest of the manual pdf reader required
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
If this solution was any help at all please press accept or ask more questions with the other button.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
May 04, 2008 | Office Equipment & Supplies
I need fax confirmation sheets printed when I fax from my HP Office Jet 8500. How do I get them to print?
on the printer itself --> press the setup button--> use the arrow keys on the printer and move to print report option --> press ok when you select print report--> Find out fax confirmation option and press ok --> turn it on.
If you do not find the Fax confirmation option under print report then find it under Tools option.
Press setup on printer --> press arrow key on printer and finid tools --> under that try to find the fax confirmation option.
once you switch on the fax confirmation option on the printer. every time you send a fax you will receive a fax confirmation also.
May 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Can't print to Konica 7030 via Parallel
You do not have the print/scan option installed on your copier. If you did you would have an ethernet port on the machine for network access and when you press the print/scan button on the control panel you would be able to access those functions. The fact that you can not means that the machine can not see that option because it is not installed. The parallel port is common and is used for uploading of firmware into the machine.
Thank You for using Fixya.
Apr 30, 2010 | Office Equipment & Supplies
How to print fax log
try this
* Press Setup menu (setup button) on the printer.
* Go to the second option print Report.
* Select the 6th option Fax log. Press Ok.
* The fax log will print now.
Apr 16, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
My HP PSC 2175 ALL IN ONE DOES NOT SCAN!PLEASE HELP!
I assume you have Vista and when the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround
Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif), click Programs, and then click Windows Fax and Scan.
    NOTE: The Windows Fax and Scanoption is available in the Business, Ultimate, and Enterprise editionsof Windows Vista. If you have the Home Basic or Home Premium edition ofWindows Vista, skip to Option two: Scan using Paint.
  2. Click New scan.
  3. Click File, and then click Scan.
  1. Click the Windows icon (c01319360.gif), click Programs, and then click Accessories.
  2. Click Paint.
  3. Click File, and then click From Scanner or Camera.
  4. Click Scan.
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Apr 20, 2009 | HP PSC 2175 All-In-One InkJet Printer
Need to clear my memory....
This is in your user guide. please read below
If you get an Out of Memory message while
scanning a subsequent page, you will have
the option to press Start to copy the pages
scanned so far, or to press Stop/Exit to
cancel the operation.
To gain extra memory, choose one of the
solutions below:
􀂄 Print the faxes that are in the memory.
(See Printing a fax from the memory on
page 45.)
􀂄 You can turn off Fax Storage.
(See Turning off Remote Fax Options on
page 65.)
􀂄 Add an optional memory
(See Memory Board on page 98.)
Apr 16, 2009 | Brother MFC-8860DN All-In-One Laser...
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Fax, Copy, Scan Buttons do not change
Sounds like switch inside operations panel has broken, there is no reset that will fix it, will need new operations panel.
the reset code on this machine is menu # 2 8 6 4 then maintence shows enter 99, the first bit must be done super quick.
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
108 people viewed this question
Ben Johnson
