Question about Bosch Nexxt 300 Series WFMC2201UC
E27 and e95 code - Bosch Nexxt 300 Series WFMC2201UC
    New Friend:
I had this problem. I tried to interupt a cycle just after it started and then couldn't start the cycle again, with the E27 code coming up.
e27 refers to a problem with the door locking mechanism which could be due to a number of causes. The problem I had was with the solenoid in the door, not a genuine problem with the door latch mechanism.
Here is how I fixed it:
(1) Set knob to off
(2) Hold down spin selector and Allergy rinse buttons and turn the knob to the LEFT (right does not work)
(3) The display then shows a number of program codes P01 to P14. (Pressing spin selector rotates through the codes).
(4) Press spin selector until you reach P02 on the display, then press the start button, the door will click and the machine will begin a cycle.
(5) Turn the knob to OFF, and then you should be able to use the machine as normal.
Posted on Jan 01, 2013
    Top Expert:
  • Bosch Master
  • 6,289 Answers
E27 is a door lock error. Couldn’t find e95 listed.
Posted on Oct 13, 2018
    New Friend:
What is a code e95
Posted on Nov 22, 2016
2 Suggested Answers
SOURCE:
ZJLimited
  • 17970 Answers
SOURCE: I have a Bosch Vision 500 with a few error codes.
E-27 means you have a bad door lock. Try opening and closing the door.
You can remove the lower front panel of the washer. There is a white plastic cord that hangs down by the drain filter. Pull the cord and pull out on the door. It is the manual unlock for the door. By pulling this you may reset the lock. If not you will have to replace the door lock.
If this isn't work, replace the door lock assembly and you can get it at a local appliance parts dealer near you with the model number. Also, could read this article about Error Code E27 for a Bosch Washer.
E-01 code indicates a ventilation problem. Other details in Bosch-error-codes.
E95 isnt listed, stay looking.
Posted on Sep 01, 2011
Bosch Silenceplus 44...just out of warranty... My dishwasher has an E 27 error code and will not start, anyone have any ideas?
What is the reason for the appearance of the e27 error of the Bosch dishwasher? What does it mean? In the instructions for different models of Bosch dishwashers, the e27 error is described as insufficient voltage in the electrical network. This means that if the mains voltage drops below 220V (or 110V in some countries), the dishwasher stops working, and the E27 error code appears. The most common failure occurs in the evening when the load on the network is maximum. That is why some the kitchen appliance owners use the delayed start function. Having loaded the device in the evening and having chosen the start in three hours, the dishwasher automatically turns on at night, and in the morning, you can get clean dishes.
The second way that will help to fix the E27 error of the Bosch dishwasher is to connect it to the electrical network via a voltage regulator.
Read more: https://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-e27/#Xrs8gAxpRuyRckCC.99
There are videos here as well
Bosch Silenceplus 44 27 error code Google Search
Oct 15, 2018 | Bosch Dishwashers
Fix error code e95
bad recirculation pump or temp sensor
Aug 27, 2016 | Pool & Spa
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
I have an induction cooktop model EW36CC55GS and when I plug it, it shows an error E95, I look for a error code chart but there is none. Can someone know what is this error?
hi i could not find this model in the uk european models but i do no that e90 codes usually relate to configuration problems possibly between user interface and powerboard . solutions are usually expensive. just check that bridging connections at the terminal block are correctly in place.
Aug 13, 2010 | Electrolux 37 in. Designer Series...
GETTING ERROR CODE E27, INK ABSORBER FULL
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
May 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Showing Code
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq12
Jun 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I would like to find out what error codes e26 e27 e52 mean on service soon of 1986 Cadillac Deville
E26 - Shorted Throttle Switch Circuit
E27 - Open circuit in throttle switch
On these 2 codes replace the TPS and clear codes (throttle position sensor).
E52 PCM/ECM Memory Reset
Have u cleared the memory? don't worry about this code.
Apr 08, 2009 | 1987 Cadillac DeVille
Bosch Nexxt 300 Series WFMC2201UC Logo
2,062 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
