Question about Gigabyte GA-8I945P-G Motherboard
System says boot manager missing on startup
Computer turns on, Toshiba logo visible, then BootMgr is missing appears
  • stballah Aug 28, 2008
    using windows XP on a Toshiba Satellite a-235 i think
  • Roberta Smith
    Roberta Smith May 11, 2010
    what operating system are you using ?
    Robert
    Brigadier General:
  • 5,158 Answers
Grab your vista cd and reboot setting the bios to boot from the cd.... you will be prompted i believe for language and keyboad settings.... your next choice is install or repair.... choose repair... in the next window choose start up repair.
Hopefully that will fix it.
Robert
Posted on Aug 28, 2008
  • Roberta Smith
    Roberta Smith Aug 28, 2008
    ok i messed that up sorry. same process with xp ... boot to the install cd.... do all the steps as tho you are reinstalling windows. but when you get to the point where it has searched for a previous version of xp .... select that version and chose repair "R"
    Robert
    Have your product key handy as it will ask you for it.
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
Missing boot manage
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot
from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Aug 25, 2012 | ASUS Computers & Internet
Boot manager is missing on qdi advance 10E mother board. \i'm trying to access the boot menu to put ubuntu on. the computer has no windows on it
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Jun 20, 2012 | QDI Group QDI Advance 10E Motherboard
I formatted Hard drive emachine T3304, Error message Bootmgr missing I want to install Windows 98
If you formatted the hard drive, you'll need to put the install disk in the CD to install Windows. But first make sure your machine is set to boot from the CD before it boots from the hard drive. You can do this from the setup menu (I think in an e-Machine you hit DEL or one of the special function keys on startup). Go to the startup option and set the CD as the initial boot device.
Your system may also offer the opportunity to press a special function key on startup to change the boot order for one time only.
Jun 06, 2012 | Intel D845PT (KD845PTPAK10) Motherboard
BOOTMGR missing >This happens after
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Apr 14, 2011 | Gigabyte GA-8SIMLH Motherboard
Computer boot screen slow?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
Error message\system32\ntskrnl.exe.
you need to repair or repair your operating system. but first you need to purchase this windows xp in order for you to repair this. yes you have a corrupted file in your system. the cause of this is the improper shut down, or a virus that infected a system folder
Apr 29, 2008 | Syntax SV266M Motherboard
Gigabyte GA-8I945P-G Motherboard Logo
455 people viewed this question
Top Gigabyte Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
joecoolvette
joecoolvette
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
