Question about GE Profile WPSR3120WWW
Not spinning thanks for the tip. However upon further inspection I found that the motor does spinin the oposite direction,but what is happening is you can see the motor shaft turning counter clockwise but the clutch hub does not move. You can hear it spinning in itself and the housing gets hot. There is no oil from the tranny getting on it. l thought that if the clutch was bad the machine would not aggitate as well?
  • 1,543 Answers
OK, if the motor is spinning but not turning the clutch hub, that means the transmission is jammed. You may be able to free it by manually turning the big pulley on the bottom of the transmissiion, but the problem will reoccur. The real solution would be to replace the transmission assembley in this case. (Transmission WH38X1002) Check the last pages of your users manual for warranty info. Warranty will vary based on model and date of manufacture. Typically, transmissions will have a 5 years part only warranty.
Posted on Aug 28, 2008
Dryer wont start, makes a humming noise. I have to manualy turn the drum then the dryer will start
Check the belt to see if it is worn or loose. If it has a capacitor start motor, the capacitor or motor could be going bad also. If the motor is spinning but the belt is not turning then you have a loose belt.
Jun 14, 2010 | LG DLE2532W Electric Dryer
The dryer does not spin, the motor runs but the drum doesn't spin
The dryer either spins because of belts/ropes or because the motor directly contacts the dryer drum. I would tip the dryer so I could inspect the drum drive mechanism(s). Make sure you don't have a belt that broke or slipped or that a drive wheel locked up.
Mar 24, 2010 | Estate TGDS840JQ Gas Dryer
Wool sweater got washed and washer stopped before "spin" - has 6" of water still in it - and will now not work. Is it just clogged? You can hear the hum of the motor but nothing happens.
More than likely you broke a belt or a drive coupling. If it is a Frigidaire, Roper, most Maytags, etc it is a belt. If it is a Kenmore, Whirlpool, or a few others made by Whirlpool, it is a drive coupling. Directions for belt change varies. Directions for changing a drive coupling can be found in the one tip I wrote. Search my tips and you'll find detailed instructions for changing it on a Whirlpool or Kenmore. Good luck.
Feb 27, 2010 | Washing Machines
Kenmore M#110.24292300 motor broke during the spin
Based upon the Model Number that you provided, this unit doesn't have a belt.
It is a basic Top Load, Direct Drive machine.
See the Sears Parts Site for your washer.!retrieve.pd?modelNumber=110.24292300
The problem is likely the Motor Coupler. See the section of the Sears site with the motor and gearcase.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Feb 01, 2010 | Kenmore Washing Machines
Dosen't spin with clothes in. works well without clothes
What you have is a bad thrust bearing. The main drive pulley and assorted washers act to release the brake in the spin mode. In the wash mode the tub must be locked down or the clothes would wrap around the agitaor and knot up real bad. The motor turns in the oposite direction to spin and when it foes a cam riser in the main puley releases the brake package and pumps out while spinning. I have a detailed repair sequence with photos, manual, and directions HERE
Jan 14, 2010 | Maytag PAV2300 Top Load Washer
Won'i\t spin or agitate. was working fine-went
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Jul 11, 2009 | KitchenAid Washing Machines
Kenmore 90 Series is NOT DRAINING or AGITATING
motor to transmission coupling or transmission itself.
Jul 02, 2009 | Kenmore 23822 Top Load Washer
Whirlpool will not spin out water
With it spinining fully it may be as simple as a sock or undergarment in the pump, if it is not spining fully the motor coupler is probably in need of replacement
Feb 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
