Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error - Canon MP830
Canon MP830 Error
Cassette
There is no paper Load paper and press (ok) ----------------------------------------- This is the first error and there is paper.  I tried turning the printer off and still showed the same error.  Thank you in advance for your help...
  • 1 more comment
  • wynandre Oct 15, 2008
    Same problem and i cant get it to feed. I just used it not even 3 hours ago. It reads error 5010 and then the printer stop's all together
  • ptcee Oct 19, 2008
    I have same problem. Just happened all of the sudden
  • guido1227 Oct 28, 2008
    There is paper in the tray but I keep getting the error message put paper in tray and press ok.
This Model has a paper tray on the bottom. Put some paper in the bottom tray and then voila..I had the same issue and i looked and the tray was empty..put some paper in..works just fine
Posted on Feb 03, 2009
  • 76 Answers
What if you change it to print from the other tray.
It sounds like one of the two springs are damaged underneath the machine causing it not to lift.
i would look underneath and inspect the springs
hope this helps
Posted on Oct 28, 2008
  • 1 more comment
  • iamuh Dec 13, 2010
    I found that the problem is a office 2007 problem as the problem goes away with either wordpad or with test page print. Looks like either the office 2007 has a bug or the canon driver is not compatible with office 2007. I hate 2007 version anyway. Wish they would just fix the bugs in office 97. i post the fix when I find out which it is.>>> SUCROMATIC
    I went to office 2007 and selected word. Then I selected a document and then select print and then print again and then properties and changed paper source option from paper feed switch to cassette and then Ok. Next I set the paper source option back to paper feed switch and it works with office 2007. Looks like a problem with the way office 2007 interprets the paper feed switch. >>>SUCROMATIC
    Another way to workaround this problem is to highlight the body of the document and paste it into a new office document. Apparently there is some hidden formatting codes in word that screws up the paper feed signal. I had a document that did the same thing and I patiently copied and pasted one page at a time into a new word document. I noticed the imbedded tables and lines in the original were bigger when pasted into a new document. This conversion happens when word prints. The document is modified to suit the print driver. Word often fails to correctly convert scaling and then it ends up sending extra **** that screws up the paper feed among other things.
Error message says cassette has no paper but there IS paper in the rear cassette
Hi!
There should be a picture of the printer on the display panel with a Light at the top and the bottom!Make sure that the light is lit up at the top side of the image,if not just press the button next to it and the machine will feed from the rear!!!
Good Luck!!
Jan 21, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I am getting a "fax output error - cassette." It
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes successfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Dec 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
We have a printer (MX870) that keeps giving us an error stating: there is no paper. There is paper in it but we cannot get it to print...it continues to give us the same error
From the service manual about the paper issue this is what it says:
***Rear tray. There is no paper. Load paper and press [OK].
Confirm that the rear tray is selected as the paper source. Set the paper in the rear tray, and press the OK button.
***Cassette. There is no paper. Load paper and press [OK].
Confirm that the cassette is selected as the paper source. Set the paper in the cassette,
Hopefully its just a setting on the printer or the computers printer properties.
Best of luck..
Jul 06, 2010 | Canon PIXMA MX870 Wireless Office...
Fax output error
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes sucessfully or you can put paper in the cassette tray...
Hope that helps.
Mar 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
MP830 Error 6A00 Error Code Alarm Flashing and Copy button Flashing. Does not respond to unplugging or turning off and back on.
6A00 means the purge assembly is jammed. That's the unit that cleans the printhead. Sometimes it will last a while when cleaned, but I just replace them.
QM2-3032-000 about $20.00 but much easier at a shop.
Oct 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MX850 - paper feed
Look carefully because it is a cassette on the bottom of your canon mx850... so the solution is: or you fill that cassette or you switch your canon (it is a button for that) to take the paper from the top...
Jul 27, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
Paper will not load and cartridges won't come all the way out
check which cassette you have it on. the lower one or the one in back.
Feb 25, 2009 | Canon MP830 All-In-One Printer
Error msg: Paper tray empty or jam, when there is not
Clean The Paper Feed Rollers Using The Unit's Operation Panel Ifthe paper feed roller is dirty, paper is not fed properly because thepaper feed roller slips. Cleaning the paper feed roller could resolvethe paper feeding problem. Please follow the instructions below toclean the Paper Feed Rollers directly from the unit. Caution:Since the cleaning process wears down the paper feed roller, performthis procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  1. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  2. Tocheck if the rollers are clean, load a sheet of Letter-sized plainpaper in the same paper source you selected in step 2, and press the<Open> button.
  3. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Sourcesetting in the printer driver. If the option is not set to 'Paper FeedSwitch', paper will feed from the source selected in the driver.
Nov 27, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
475 people viewed this question
old marine
old marine
