Turned the big screen toshiba theatre view on, worked good for about 2 min. Then just shut down, not the red power light comes on, but no picture or sound.
Water from air conditioner dripped on back of 56in.toshiba big screen.now its has no sound or picture.its been sitting for 2yrs and has had just a good as picture a smy flat panel.every 1 says im stupid for keeping it but iwould like to know if it is doable by me.i believe i could do it if i knew what part i needed.thx
Posted on Jan 30, 2011
Toshiba 51 inch theatre view Blinking red light -- no sign of picture or sound
Had the same problem on my 42in. and it ended up being 2 of the fuses and 1 board had to be replaced.About 900dallars worth of work,it was covered under warr.
Nov 29, 2009 | Toshiba 53H71 53 in. Rear Projection...
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
TURNS ON OK THEN SHUTS DOWN, GREEN LIGHT STAYS ON
Mine does the same thing try a new lamp I am with what I have read this is the best solution. I have had green screen two fans replaced and now this. The picture was great but with all the problems i would never but a sony product ever again for anyone out there you should tell them sony sucks and send them to this web site for clues. Good luck.
Dec 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
