Question about Refrigerators
Dometic frig 2852
Elect side of frig dosnt get cold. on gas it works fine.
There was a recall on the frig by Dometic.
Posted on Aug 28, 2008
Dm 2852 dometic
check seals if bad will frost up
Aug 09, 2014 | Dometic Refrigerators
I have a Domatic RM 2852 in my RV. The freezer works fine but the refrigerator won't cool to 40 on electricity. It cools fine on gas.
You need to unplug the heating element from the circuit board and using a digital multi meter check the ohms. You should read approximately 44 ohms +/- 10%. If it is out of range change the heating element.
Aug 15, 2013 | Dometic RM2852 Refrigerator
I have a dometic mod.2852 refridgerator/freezer that was working fine until a day ago when it stopped getting cold in both parts. It has power. the space between the freezer and refridgerator is very warm....
Check this link to dometic recalls first and enter your model number and serial number. There may be a recall on that fridge.
http://67.238.126.140/recall.php
Jun 13, 2011 | Dometic RM2852 Refrigerator
I got a RM 2852 IN A 5TH WHEEL. It will work fine on gas,but 110v does not work,Any suggestions? Thanks,David
We were told that its a faulty control board on most Rm2852 units. a factory defect.
Ours did the same thing first the gas would not stay on to cool but the unti worked fine on electric...now the electric is not working...the heater gets hot and burner comes on but does not stay on..they system shuts down..and will not cool. .
Jan 29, 2011 | Dometic RM2852 Refrigerator
Hi,have a dometic rvfridge ,gas and e,ec,was
I would recomend that you downlaod the diagnostic sevice manual, and test a few things yourself.
Roy
Jul 29, 2010 | Dometic RM2652 Refrigerator
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
228 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
