Question about Mitsubishi VS-50603 50" Rear Projection Television
I have a Mitsubishi VS-50603 that will not turn on.
When I plug in the set green LED automatically turns on, it does not blink just a solid light. TV set will not turn on
  • 927 Answers
Good Day, jessayala;
It sounds like you may have Ethylene Glycol on the boards, leakage from the TV's CRT's. The Glycol is a fluid that help's the tube cool. If you are not handy, very, very handy, I would call an Authorized Service Center to come out and give you an estimate before the repair is performed.
Good Luck, big IRISH......PS..... If can handle your self ..... come back here.
Posted on Aug 28, 2008
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Dec 06, 2009 | Televison & Video
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50603 Wont Turn on
The power supply will need to be changed. The capacitors inside the power supply are not sending the correct amount of power to tv and will need to be changed.
May 13, 2009 | Mitsubishi VS-50603 50" Rear Projection...
I have a Mitsubishi VS-50607 and it will turn on then off.
This solution fromtroylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
LED Blinking
Okay 2 blinks isnt a error code, so your set isnt shutting down due to a protection issue, so I would suspect one of the low voltage regulator transistors or the horizontal output transistor as being defective
Jul 06, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Blinking green light
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V,
105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with
part # 181P734030 (680 uFD, 16V, 105C).
I have done one of these repairs and they are quite difficult so have a tech do this repair.
Feb 14, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS50603 will not turn on
If you are not a tech the tv needs to go to a tech to be fixed.the probleis in the power supply or related circuit good luck.
Apr 01, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
