Place some kitty litter crystals in a pair of nylons and place it in the area where the water is collecting. This will help absorb any excess water build up.
cos you have condensation inside due to the fact that it is not frost free OR you have a seal leak.....OR the door is constantly open and closed (my beer fridge is like that.....)
http://www.haieramerica.com/en/asset/archived/BC112G.pdf is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit. Hope this helps!
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
