After format and fresh install win 2000 say key code not correct now i cant finish reload
  • Ravel Lively
    Ravel Lively May 11, 2010
    Sounds like you are trying to enter an invalid Win2K serial #. Is this an example of a pirated version of Win2K???
    Sergeant:
    Champion:
  • 246 Answers
The key is correct
the CD is not a original CD
Posted on Aug 28, 2008
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Hi i have a toshiba qosmio x305-q712 laptop it came with windows vista then they sent me 7 upgrade how do i recover the laptop to factory seting i know there is recovery disc creator but i just wasted 5...
* It is not necessary to back up ur data. U can simply run the Windows 7 upgrade, it will not delete ur files and folders. It will only replace the windows and system files.
** If u want to back up ur data then simply copy ur all data to another partition except C drive (System Drive) and then install a fresh copy of windows 7 and by format only c partition.
*** If there is only a single partition, then simply copy all your necessary data to CD/DVD aur pen drive aur any external hard drive and install a fresh copy.
**** U can also use Partition Magic to make two partition by cutting some space from C drive in case of only one partition.
Jan 31, 2011 | Computers & Internet
After installing windows 7
Just "reuse" one of the keys -- since the "hardware" is the same as when you "used" one of the keys, you can "reuse" a key.
Jan 02, 2010 | Microsoft Office Home and Student 2007 for...
Got win 98 disc restored pc but no key code for it
Giving away key codes is illegal, you won't find one here.
Oct 24, 2009 | Computers & Internet
I have a properly licensed copy of Win 2000 pro on my desktop computer. I have misplaced the CD Key. I think it washed away in an unfortunate aquarium accident. I am upgrading the MB, CPU and video and...
from what i can find your still in luck heres how
If you do not have the product key you will need to use a third party tool like the one from "Magical Jelly Bean Software," to find out what your functioning computer's Windows Operating System Product Key is
Sep 25, 2009 | Microsoft Windows 2000 Professional for PC
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
I want to crash my computer and reload os and software
you dont need to crash your windows all you need to do is to reformat your hard disk and reload the operating system .
Dec 08, 2008 | Computers & Internet
How to hard format 6300
If it would SIM lock then you could get the PUK code and unlock it. If it as phone lock then remember the correct unlock code and try it after some time. Dont try it continuously. If you try continuously, if it's correct code also it won't work. The second solution is to reloading the software in your mobile. This may erase all data in your mobile. you may reload this in any mobile service centers. This method has to work. Thank you
Sep 06, 2008 | Nokia 6300 Cellular Phone
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
