I have a Sanyo TV model HT30744. The problem is that there is sound but no picture when the TV is turned on. After about 10-15 minutes a picture will appear. Distorted at first, the picture gradually improves until the picture appears normal. The picture will sometimes go blank at times and then return to normal. Is this a problem that can be fixed at a reasonable cost? The TV is about 3.5 years old. Thank you Dale Mrotek at dmrotek@wi.rr.com
  • dmrotek Aug 28, 2008
    This TV has a picture tube, it is NOT a projection TV
    Genius:
  • 1,011 Answers
Sir/madam,
It sounds that a voltage regulator problem and weak picture tube.
check out it's working properly or not?
thanks
good luck
Posted on Aug 28, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Aug 28, 2008
    Dear Sir/madam,
    Also check these things....
    First check: High voltage flyback transformer. If you have sound, but no picture, this is probably the culprit.
    Second: The horizontal deflection amplifier.
    Third check: Main power supply; look for bad rectifier bridge and/or bad electrolytic filter capacitors.
    Hope this helps.
    Guru:
  • 674 Answers
This problem could be fixed by you with a few tools and you wanting to take it apart. if you want some one to do it for you i would say the tv isnt worth repairing.
good luck
paul
  • paul erickson
    paul erickson Aug 28, 2008
    i just checked the specs on your tv. the labor rate is so high anymore that it realy is tough to have someone repair this tv. and yes there has been changes in the new tv's since you bought this one. you spend $200 on it and for a little more you can get a new on with warranty.
  • 6,487 Answers
Yes, its still reasonable to have it fix , because the tv will be working fine after they replace probably the tube.
Hope that helps.........
How to fix blurry picture on sanyo ht30744
Turn tv on picture is clear and sharp. no problems at all. However, after 30 or 60 seconds picture is blurry, color is distored. stays that way
Dec 31, 2010 | Sanyo HT30744 TV
Sanyo HT30744 Aspect Ratio Help
Do you still have the original remote? If so there is a button that says "Pix shape" that will change your aspect ratio for you. If you are watching something in HD it should say "full". If it is analog it will say "normal" in 4x3 format. If you want it stretch hit it till it says "zoom 1" or "zoom 2". If you don't have the original remote I am not sure how you would change it. You can find them on ebay if you need one. Hope this helps.
Jan 30, 2009 | Sanyo HT30744 TV
Green screen
Not really sure how much the tv weighs, but I know it is a bunch. I have 2 of these t.v.s. One I bought at Wal-mart and after about 6 months it started doing this green screen also. I would normally give the side of the tv a good wack and it would go back to normal for awhile. The other tv I bought from my neighbor who was moving for $25. The problem with this one was the "no picture but I have sound". If I wacked this one I could get the picture to come back on for a while, but it would go out again. Well just the other day I took the back off the "no picture" tv and was looking around. I noticed that the circuit board that is attached to the picture tube was loose. I pushed it back down on the tube and put it back together and the picture has been fine since. So I thought I would check the one with "green screen" issues and sure enough that circuit board was loose also. Pushed that one all the way back down and have not had any issues with that tv either. Hopefully that fixed my problem, I guess time will tell. Maybe it will fix yours also.
May 19, 2008 | Sanyo HT30744 TV
Sanyo remote control hdtv ht30744
You need the original factory remote control. Do a web search for Sanyo. Go to their tech support. They can advise you about how to order a new remote for your set.
Jerry G.
May 04, 2008 | Sanyo HT30744 TV
Sanyo HT30744 tv
You have to find out the cost of the repair itself to make a decision.
I am not familiar with this model. I can speculate from experience going by your description.
If it is a CRT set and there is no picture the fault may be with the high voltage section, or a scan failure. It is also possible that the CRT itself is in failure.
Jerry G.
Apr 19, 2008 | Sanyo HT30744 TV
Green screen
Open it up and check to see it the circuit board attached to the tube is seated all the way down. Both of mine were not attached that well so I pushed them back down and have not had any problems since.
Nov 07, 2007 | Sanyo HT30744 TV
No color on one channel
Some models of TV's can remember the user settings for each channel programed. Go in to the user menu for the video setup and see if the colour (chroma) is turned down.
Jerry G.
Jul 23, 2007 | Sanyo HT30744 TV
My picture is tinted green.
could be that you have speakers around the tv check to see if that is so. and remove the speakers.good luck.
May 18, 2007 | Sanyo HT30744 TV
On and off picture and color weak Sanyo HT30744
I had the same problem with my refurbished HT-30744 model and my mom's HT-32744 model. It was either try to fix it or buy a new one, so I figred had nothing to lose.
I removed the back cover, unseated the picture tube driver board from the neck of the picture tube (it just pulls off), put on a dab of di-electric grease on the connector on the card, reseated the card, removed and re-applied more grease, reseated the card and the picture has like new for 2 weeks now!
This was a very easy fix.
Jan 21, 2007 | Sanyo HT30744 TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
