Check your hot/cold inlet valve and solenoid. It sounds like your cold water side of the valve is stuck shut. The valve is found by following the inlet hose right to it. Also, do you have a domestic well as water supply? Sometimes fine sand from a domestic well will plug the valve screen. It is also possible that other mineral would plug the screen. These things would happen gradually, though, not all at once.
If you select warm water wash, do you get warm, hot only or cold only? If temp OK, but fills slow one of the fill hose screens is clogged. If only hot or only cold the opposite fill valve solonoid is bad.
Depending on the age of the unit you may be looking at a faulty switch. Sometimes the contacts for the cold water solonoid on the switch may be fused shut and therefore you will always get cold water no mater what you select. If hot water is what you need the easy way to do this is select hot water and close the tap for the cold water until needed again.
Hope this helps
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Some whirlpool washers have had A similar problem. They had a intermittent water temperature switch issue. Sometimes they put hot water in when cold was selected. This is probably the same problem as yours. I would replace the water temp switch.
hey there sounds like your hot falve is faulty, if it is faulty they tend to either switch off and not open to let water in, or not open at all, get a service tech to look at you hot valve.
sounds like your washer has an auto temp. control if so the washer mesures the temp of the water and put in the manufacture set temp for that setting this board could be bad alowing only cold water to come into the machine. you could also have low hot water pressure at the washer be sure the hot water is turned all the way on. you may want to check to make sure no trash is in the hot water side of the water valve there is a screen in there where the hose conects you can remove that screen and clean it im sure one of these solutions will help you
new washer valve on washers are designed to be "energy saving" most are 70/30..on warm 70 percent cold and 30 percent hot also new temp controls will reduce temp to a "safe level" by adding cold even on hot setting the on/off of water flow is being controlled by thermal sensor in water line on valve output ..in other words it's normal
