Question about Motorola Mobility RAZR V3
MOTOROLA V3XX SEARCHING FOR NETWORK
I put my old main board in a new motorola v3xx housing because I broke the old one. Everything works except it can't connect to a network. It was an att phone that I broke, I think the housing was att as well. As it powers on it says att and my phone number comes up. any suggestions
  • Chris Havens
    Chris Havens May 11, 2010
    I know this might be a stupid question, but did you include the antenna when you transfered main board?
    Also, when you broke your old phone, was it moisture or impact related? You could have caused a hairline crack in the IC board or a cold solder break in the RF.
    Brigadier General:
  • 7,752 Answers
CROHUNTER - you should take it to a mobile service center and ahve it tested the board antenna may need servicing.
Posted on Aug 31, 2008
Need to unlock Motorola Razor V3xx cingular to work on Verizon
It's not possible as the two networks are not compatible with each other for the V3xx. With other phones it may be as easy as swapping SIM cards.
Motorola Support
Apr 12, 2014 | Motorola Mobility New 3g Razr Razor V3xx...
I got an old razr v3xx from pawn shop but it has a subsidy code on it i cant get into the phone i tryed all 0000 didnt work tryed 1234 didnt work can anybody tell me how to remove it or reset the phone...
The mobile is locked with a particular network.You need to remove that restriction.You have tried the default unlock codes meant for the keypad lock.To get the unique unlock code(subsidy code) for your Motorola Razr V3XX from Theunlockspot.com wherein you need to specify the country and network to which the mobile is locked to.You will receive the unlock code along with free unlock instructions.
Apr 18, 2013 | Motorola Mobility RAZR V3xx Cellular Phone
Need subsidy password motorazr v3xx my ime number is 354094010174808
Hi to get subsidy password visit mobileunlocksolutions.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they send you codes to unlock your Motorola razr v3xx mobile.
Aug 14, 2012 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Razor V3xx has frozen keys except on/off button
Take the battery out and set it under a hot laptop for a half hour.
Jun 12, 2009 | Motorola Mobility RAZR V3
Cant pick up a network, it keeps searching
If it is continueing to search for a network. Wanna make sure you have the correct simcard for the carrier in your phone. And it is in the phone correctly. Maybe the phone is NOT completely unlocked. If that all works, check your network in the phone.
  1. At the main screen, press the Menu key.
  2. Scroll to and select Settings.
  3. Scroll to and select Network.
  4. Scroll to and select Network Setup.
  5. Scroll to Type and select Change.
  6. Scroll to and select AUTOMATIC
SAVE. Besure once a day to power down the for about 10-20 seconds a day.
Feb 14, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Razr V3XX searching for network
you must have a crack in the phone board IC or RF related so take it to a mobile shop to see if that happening.
Aug 28, 2008 | Motorola Mobility RAZR V3
My razr v3xx keeps searching for network
maybe the antenna is not in correctly...you should take the phone to a mobile shop and have them check it over for you.
Aug 06, 2008 | Motorola Mobility RAZR V3i Cellular Phone
After getting Motorola V3xx wet and drying for several weeks, everything works EXCEPT the center Select button. Can use "Select" when offered, but usually only options appear that have nothing...
you need to take the phone and have the flexcable replaced and still have the phone service to remove any further moisture that may have been still inside the main board on the phone.
Jul 10, 2008 | Cell Phones
How to i change my motorola mobile phone to dual band network
You need your phone unlocking this should cost you around £10this will enalbal you to accsept all networks
Jun 18, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
No network
the antenna need to be replaced on the main board
Sep 20, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3 Logo
102 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
