Question about Karcher 2500 PSI Pressure Washer
My 3.99 Karcher pressure cleaner seems to keep going on,off,on,off when i release the trigger.It used to keep going momentarly when the trigger was released until the pressure built up,then cut off until the trigger was pressed .Now it goes on ,off,on,off and has decreased pressure.
  • Anonymous Mar 20, 2014
    no pressure when trigger activated on the hand gun
  • Steve Hanlon Feb 05, 2015
    if the machine is pulsating [ on off on off ] for sure it has a leak either in the manifold or head could be a fine pin hole thats all it takes quite common in karchers , 1 of the critical things with high pressure washers is you must release all pressur from the machine via the wand after every thing has been turned off other wise the machine stays under pressure , if you have some mechanical knowledge they are simple to pull apart to replace the head or manifold , approx cost of parts $120
    Scholar:
  • 121 Answers
Hi! robcarroll
Did you purge the air from the pump before starting the motor.
InMrFixIt
Posted on Aug 28, 2008
Karcher G3050OH when trigger is released it can't be depressed again until machine is shut down. Pressure will release after shut down.
It sounds like you're not pulling hard enough. When the machine is running it's under great pressure you have to squeeze the trigger very hard
May 05, 2017 | Karcher Garden
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
May 14, 2012 | Karcher Garden
Karcher k1 leaking from inside casing.
The most likely issue, which seems to occur alot with karcher, is a cracked water pump. What happens is that as you release the trigger on the handle, the rise in pressure should cut off the motor, but as it also cuts off the water flow at the wand end and the motor spins a few more revs until it stops, then there is a huge pressure glitch which blows apart the weak plastic pumps that they use. Since the plastic cracks it is very difficult to repair and the only option is to go and buy another. BUT...this time tape up the trigger on the handle so it is always on and then it won't blow itself up. Just use the unit on/off switch to turn the motor on and off.
Apr 11, 2010 | Karcher Garden
Pulsating when idle
The motor doesn't pulsate when you are spraying and pulsattes when not spraying is normal otherwise the pressure will just keep building and burn out the pump. However, if you are not using the sprayer right away then the unit should be shut off until your ready to start again.
I hope the answer is helpful, please rate if the answer has helped in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Karcher K 3.98 M Electric Pressure Washer
Karcher 3.98M Switches On and Off after Releasing Trigger
Yea the pressure cleaner has a internal water leak it thinks you are trying to turn it on then kicks in and realises that you are not...
on these cheap units sometimes it is not worth fixing if you still have good pressure... other wise you could take it to a tech and get the plastic head and valve assy replaced that will most likely fix it very common problem....
regards
Brad:)
Sep 06, 2009 | Karcher K2.26 Electric Power Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Apr 05, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2400 psi blaster When you release the trigger it will not pick up pressure when you use it again
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Sep 12, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
687 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Phil Rivera
Are you a Karcher Garden Expert? Answer questions, earn points and help others
