Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Primary drive after switching to synthetic oil and adjusting the chain tension, I went on a 500 mile trip. The further into the ride I went,it started making a clunking noise but only noticable at idle.Doesn't seem to be getting any worse. Seems to come from area of the lower end. Could I have overtightened the chain and caused damage, and what typically would that damage be?
    Genius:
  • 2,028 Answers
Most likely what has happened is that the tensioner bolt has backed out a bit, and is causing the primary chain to bump the case. I've had a few bikes that this has happened with. It won't cause any real damage, just a few scrapes on the inner primary, but you do need to get it right. I recommend that you replace the factory tesioner with a Hayden M6 automatic tensioner. This way you will never have to adjust it again, and it will always be adjusted properly. Occasionally you will have to replace the springs, about every 7 to 10 years, otherwise it takes care of itself.
Posted on Aug 28, 2008
How to replace the starter on a 2002 harley
Pretty entailed job. Not like a car.
You will need to remove the primary and possibly the clutch basket/ starter ring gear to access an internal fastener holding the starter to the inside of the inner primary.
Will probably need a primary cover gasket and a quart of synthetic (klotz 80-90) primary chain case lube.
While you're in there you should probably check & adjust primary chain tension and the Delrin shoe the chain rides on.
Completely drain the old primary lube, don't mix old with new, the thing only takes 18-22 ozs (so okay, maybe you need 1.3 qts).
Consider the different kW starters available and get the one that best suits your needs (is the motor built? high use? etc...) Terry components makes great components with WARRANTIES!!
Gasket $20-$25, klotz fluid $16-$20.
Starter drive clutch $35 to $100+.
Starter $380- $490 and up
Also jack-shaft assemblies, ring-gears, etc...$50, $80, $$$$$
Finally; if you have a large displacement or built motor you should have compression releases. Use them religiously.
Oct 08, 2014 | Motorcycles
2007 1200 sportser sounds like the gear chain is lose how do i fix it...
If you're talking about the primary drive chain on the left side of the bike, with the engine cold and engine OFF, remove the inspection plate at the top center of the primary cover. Stick your finger in the hole and lift the chain. You should have 3/8" to 1/2" up and down movement. If you need to adjust the tension on the chain, loosen the lock nut on the adjuster bolt on the bottom of the primary case. Turning the bolt upwards tightens the chain. Once you get the tension set correctly, tighten the locknut. Make sure the oil level in the primary case is correct because this same oil lubricates your transmission. You don't want to run your transmission low on oil. If you're in doubt, drain the primary and refill with one quart of oil. There may be a lubricant level plug in the backside of your primary cover.
Good Luck
Steve
Aug 06, 2011 | 2006 Harley Davidson XL 1200 C Sportster...
I have a big twin Harley. I use synthetic oil in the engine. I ride about 14,000 miles per year. I live in WI How often should I change oil.
It really a question about comfortability. Some folks change their oil(s) every 5000 miles (or more), some every 2500/3000 miles and some might do it as often as every 1000 miles. Depending upon the model year of your bike current H-D specifications recommend changing the engine oil, transmission fluid, and primary chain case oils every 5000 miles whether using conventional or synthetic fluids.
Aug 20, 2010 | Harley Davidson FLHTCUI Electra Glide...
Engine chain type noise at low rpm engine has approx 40 thousand kilos on a 2008 electric glide classic
Have you checked the tension on the primary chain lately? Take the oval shaped inspection cover off the the primary cover on the right side of the bike. Check the tension on the top run of the primary chain in the middle of the run. You should have between 5/8" (15.8mm) to 7/8" (19.0mm) with the engine COLD. To adjust loosen the nut that holds the primary chain shoe in place and raise the plate to tighten the chain, lower it to loosen. Since working through the inspection cover hole is tedious, some people elect to take the outer primary cover off and then set the tension. Refill the primay with 36 to 42 ounces of the appropiate oil. Harly uses H-D Syn3 20W50 synthetic engine oil in the primary.
If the noise seems to be coming from the right hand side of the engine, it could be the cam chain tensioner and shoe. To repair this requires going into the cam chest. This is something that I do not recommend for the amateur mechanic. There are also some special tools required to work in this area.
I hope this helps
Good Luck
Steve
Jul 20, 2010 | Motorcycles
All i want to know is on the timing chain does the tenchiner go on top or bottom
How is the setup? You have a bar that is attached to the primary and the tensioner rides up and down in some notches? If so, that is the old setup in the big twins as well, the tensioner went up against the chain at the bottom run of chain and pushed up. Hope this helps.
May 28, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Is there a certain brand or weight of oil I should be using in my 06 sporster 1200 custom?
20w/50 synthetic
04-up is 3 qts.
Drain oil hot, r&r filter, put in oil,........let a couple ounces drain out of the hose to bleed the air out to prevent cavitation inside the oil pump.... run engine about 10 minutes, shut off & let sit for about 2 minutes. Check oil level with bike upright, oil should be at top mark on dipstick, fill as needed.
Don't forget about the Primary Oil...1 qt.
Also remember, there is WAY more to maintaining your bike than just an oil change, belt tension, throttle cable lube and adjustment, clutch adjustment, clutch cable lube and adjustment, primary chain adjustment, brake inpsection, tire pressures, fork oil every 10k miles, steering neck bearing lube and adjustment every 10k miles, etc.
May 27, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Im after service guidelines for 96 evo
In my opinion, the Evo engine is the best engine Harley ever designed. Sure it has a few problem areas but as far a good basic engine or an engine that can be modified for tremendous power, the Evo is the one for me.
Basically, change the engine oil at least every 3000 miles, the primary oil and transmission oil at 5000 mile intervals. Personally, I change the oil in all three every 1000 miles. Oil is much less expensive than engine overhauls.
Check the adjustment of your primary chain everytime you change the oil. Remove the tappet filter screen, (little plug on the crankcase near the oil pump), and clean that every oil change.
Other than that, keep an eye on your rear drive belt tension, your brake pads and fluid level. That's about it. Today's Harleys are better than they've ever been. Take that from someone that works on the old Pans, Shovels, and Ironheads. Today's Harleys are real feats of engineering. Enjoy your bike and ride carefully.
Feb 09, 2010 | Harley Davidson FXDWG Dyna Wide Glide...
Purchased a york hydraulic primary chain tensioner for my 2005 HD vtwin and it came with no instructions. Believe I have it installed correctly but any particulars for adjustments I need to know about....
Once they're installed, they usually self adjust from what I've been told. It works hydraulically. As the spring pushes up on the bottom side of the primary, the sucks oil in to keep the tension on the chain.
I've heard from some that they have noticed a bit more noise from the primary due to the added tension on the primary chain. Personally, I guess I'm just "old school". It ain't too much trouble to check the chain tension every two or three thousand miles. But, then again, I work on the things for a hobby.
Jan 24, 2010 | 2003 Harley Davidson FLHTC Electra Glide...
Oil light goes on...had a dry stick 4 1/2 qts put in. no oil on ground. after oil change light went on at 70 miles.. on 15 secs then off for 5 miles then on again 15 secs--- off 4 miles--off 3 miles- off 2...
if it's not going onto the ground, and it's not being burned, check the positive crankcase ventilation and the exhaust gas recirculation valves for oil seepage...also check your air filter, if its got oil on it replace the pcv valve.
Jun 19, 2009 | 2003 Volkswagen Jetta TDI
Lands Phones Logo
124 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
