Question about Toshiba Satellite A135-S4527 Notebook
Toshiba power saver fatal error code 0x57
Computer automatically powers down to save mode but can not be restarted except by hard boot (taking our power bar)
When I restart I get message 'toshiba power saver fatal error code 0x57'
When I try to reset power saving options to never in control panel it does not let me.
  • thug_poet360 Aug 28, 2008
    i have this exact sae problem
  • tranchihung Oct 05, 2008
    I use Toshiba Setelite A215-S5824 and I've changed from Vista to XP. So some feature of it has been lost. For example, Power saver and hot keys. Please help me to fix these problems. If you have any information, please send to my email.
    thans!
    My email: chihung1407@gmail.com
    Problem Solver:
  • 3 Answers
Try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Posted on Aug 28, 2008
Toshiba Power Saver. Fatal error Code 0x7E
uninstall Power Saver while in Safe Mode, reboot into Safe Mode again, and reinstalled Power Saver
Jul 05, 2012 | Toshiba Computers & Internet
The pc entering in pwoer saving mode and
  1. Start or restart your computer.
  2. Press the F10 key when the F10=Setup message is displayed.
  3. Select the appropriate Language option.
  4. Select the Power menu.
  5. Select (if not already selected) the Energy Saver item.
  6. Press the Enter key.
  7. Select Advanced .
  8. Press F10 to save the change.
  9. Select Power > Timeouts > Hard Drive Timeout > Never .
  10. Press F10 to save the change.
  11. Select the Power > Energy Saver .
  12. Press the Enter key.
  13. Restore the desired Energy Saver Mode (Disable or Minimal).
  14. Press F10 to save the change.
  15. Select File > Save Changes and Exit .
Feb 03, 2010 | HP Compaq d530 PC Desktop
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
May 05, 2009 | Computers & Internet
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba power saver fatal error 0xb7
Okay I don't know if this will work for you, but bear with me, cause this is what I did and it fixed my fatal error.
First Download System Mechanic (theres a 30 day free trial you can use for the time being)
After it's done downloading and you've installed it. Do a deep Analysis of your system, and some errors will come up. Have the program fix them for you (if there are some you don't want to fix just hide them, and if your unsure about them, just go ahead and fix them). After this restart your computer whether or not the system mechanic asks. If after a restart it still gives you an error, download the latest version of the toshiba power saver which is currently 7.08.05. I have a toshiba U205 so there wasn't a specific one for mine, so I downloaded the Toshiba Satellite R20-ST4113 Power Saver Utility 7.08.05 Windows X.
Which still worked for my system since it's an XP. If yours is a vista, I recommending finding one for vista.
After this again restart your computer to see if it helped. I hope it helped with your problem. If not i'm sorry I couldn't give anymore advice.
Jul 30, 2008 | Toshiba Computers & Internet
Toshiba Power Saver
It sounds like the built in powersaver utility is crashing. Assuming you can log into the OS after the error, go to Control Panel - Power Options and change to some other (or none at all) setting. And/or uninstall the application completely.
If you can not even get into windows you could try changing the power settings within to bios to disable power saving at all, and that might allow you to boot properly and then turn off/uninstall as described above.
Jan 16, 2008 | Computers & Internet
Power saver error 0x5
Dec 10, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite M45-S351 PC Notebook
cutemah, Is your cd/dvd internal or usb? Have you tried to login using safemode? When the first Toshiba screen appears press the F8 key. Choose safe mode. Since you say the cd/dvd isn't being recognized that too may be the problem. Try removing the cd/dvd player and see if the machine starts. Is the error code only 0x57 or is there more? It is sounding more hardware related than software related. What program are you using to format the hard drive? Send me a little more information please. Let me know what happens. Good Luck, Tim
Mar 14, 2007 | Toshiba Satellite M45-S351 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
734 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
