Question about HP iPAQ RX3715 Pocket PC
HP iPAQ 3715 - screen problems
I recently purchased an iPAQ 3715, but suspect I've got a faulty unit - the screen is prone to flicker & then die (either to a white or grey screen). However, it *seems* to be related to the wi-fi settings. If wi-fi is disabled, the device appears to be quite stable. The same seems to be true if wi-fi is enabled & a strong connection is available. However, if wi-fi is enabled but no connection available the screen will immediately die, although the touch screen remains responsive. I've discovered that I can enable wi-fi, see the screen die, but then tap the screen where the wifi button is located & it comes back to life! Does anyone have a resolution for this, or confirm my suspicions that it needs to be returned as faulty? Kind regards
    Master:
  • 450 Answers
Return it as faulty. WiFi should not impact your screens ability to stay on.
Posted on Sep 08, 2005
SOURCE:
Stange battery performance???? - iPAQ h2200
surely the problem is with the battery ask for a replacement, try to find one which has the same mah with the battery you got along with the phone.
Apr 15, 2009 | HP iPAQ H2210 Pocket PC
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
Download driver for hp ipaq rx 3715
Hi!
You can download the drivers for your hp ipaq by clicking on this link.
Under the window it will open the extreme bottom there is a download link.
Thanks
Rylee
Jan 29, 2009 | HP iPAQ RX3715 Pocket PC
Ipaq 3715 tapping problem
have you downloaded any viruses? if not try another hard reset is the screen cracked?
Jan 07, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Passing allign screen test
I am not an expert on this. But I just had a problem similar to this as the unit kept reporting a FAIL on the screen calibration test. So this is what I did and after I did this, the screen calibration passed.
I went back to the screen alignment tool and performed a screen alignment with the stylus and this solved my issue. I then checked the self test aand it passed. This may not workfor you, but you can try it. Also you might want to check to see if you have any third party programs that are affecting this. The only way, you'll know is to remove those third party programs, one by one and repeat the self test to see if this corrects the problem. Good Luck
Aug 04, 2008 | HP iPAQ RX3715 Pocket PC
Helo i have a problem
The dreaded "allign screen problem" strikes again. This is a known bug of these rx ipaqs. You should simply try to see if the ipaq passes this stage if you try to allign the screen a few times. If not, try a firmware update/rom update (from the hp site) If this woun't work then the problem is located on the motherboard,where a small chip called the touchscreen I/O controller has failed. This isn't fixable by replacing the screen, only the whole motherboard. Unfortunately most of the first generation rx 3715 units (first revisions) carried this problem just waiting to happen.
Please ask more details if you need to better understand any of these methods above.
Jul 11, 2008 | HP iPAQ RX3715 Pocket PC
HP iPaq 3715
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
May 28, 2008 | HP iPAQ RX3715 Pocket PC
No power to Ipaq 3715
Just did this one, please refer to
http://www.fixya.com/support/t395532-not_turn
For the solution
Jul 29, 2007 | HP iPAQ RX3715 Pocket PC
Hebrew Support for IPAQ 3715
Try Laridian.com They specialize in Bible and some language software for PDA's. Good Luck.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
195 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
