Question about Magellan GPS
How to set the time on Magellan - Magellan GPS
Posted on Jan 01, 2009
Magellan roadmate 2036 how to set my local time
1. From the
Main Menu screen, tap the Settings icon .
2. Tap
Setting Languages
1. Access the
System Settings menu (above).
2. Tap
3. Tap on the desired language.
4. Tap the back arrow .
5. The Magellan RoadMate receiver will reboot if you change the language.
Setting Auto Power
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
1. Access the
2. Tap
Auto Power.
3. Tap on the desired duration.
Setting Brightness
1. Access the
2. Tap
3. Tap in the brightness slider to set the brightness of the display.
Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
power. Check to turn this option on.
Setting the Time Format
1. Access the
2. Tap
Time Format.
3. Tap on 24 Hours or 12 hours with am/pm.
Selecting the Time Zone (daylight savings on/off)
1. Access the
2. Tap
Time Zone.
3. Check Auto Time Zone or select your time zone from one of the cities in the list.
Jun 27, 2011 | Magellan 2036 GPS Receiver
How do you set the time on Magellan sports watch?
Follow this link and you will see genuine Magellan watches: Check out : Collection, Portrait, Media, Press review and you will understand there is no such a watch as Magellan Sports watch. Unfortunately you are the owner of unknown watch, probable Chinese made.
Feb 26, 2010 | Watches
My magellan maestro 4040 is an hour ahead on the time. I have tried changing the time zone and region but no luck. Any ideas?
did you check off for daylight saving time?
its in the time zone settings..make sure the magellan is acquiring the satellites (it it displaying your location...if it is, its probably because the daylight savings time isnt checked
if thats not the problem, let me know and ill help you further.
Dec 29, 2009 | Magellan Maestro 4040 GPS Receiver
My Magellan Triton 500 does not display the correct date or time. Can you help?
Assuming that you have the latest firmware installed. Do a MENU>>VIEW>>SETTINGS and then using the down arrow to scroll down. The Date and time and language and power settings are out of sight. scrool down and you will see date and time.
Dec 03, 2009 | Magellan Triton 500 Handheld GPS Receiver
Non accurate time keeping on Magellan 1215. How
go to the system settings and change your time zone to your region and also make sure you check off daylight saving time box if you observe it in your location.
Aug 29, 2009 | Magellan GPS
Magellan Roadmate 1412 stuck on settings
There's a small button on a side to reset it to manufacturing setting. Try it. You can also contact magellan tech support.
Jan 09, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
Change the time on the magellan roadmate 1212?
I was in same situation with a magellan roadmate 1212. From what I can tell, the "daylight savings" is not what many of us may be accustomed to... that is, that it means that the location you are at follows daylight savings as happens with Windows or many other devices.
I bet those in Arizona never had a problem becuase they don't follow time zone... let me explain....
The daylight savings seems to state "are we currently under daylight savings time?" if we say yes (as you would normally state in your Windows computer setting (that would determine when daylight starts and stops and adjust pc time accordingly), the magellan 1212 instead will "ADD" one hour to the time stated by the Satellites regardless on whether it is summer ... or not.
So, if you happen to live in a time zone that follows "daylight savings" and you currently are under "daylight savings" time, then set it so in the "time zone".
So, there are two things you have to do:
/menu/user options/system settings/time zone/
1)Set your time zone
2)If currently under Set/unset the daylight savings set button to yes and manually move to no when not on DLS.
The explanation I found in MagellanGPS website is below, but never mentions what is the meaning (I should say effect) of the "daylight savings" button checkmark.
Magellan GPS receivers are not able to set the Time manually. In order to have the correct time set on your Magellan GPS receiver, you must set the proper time zone you are located in (ie Pacific, Central or Eastern). Once the time zone is set the exact hour and minute will display as information is received from the satellites. The following information will assist you on setting the time zone on your Magellan GPS. For Outdoor Triton series 200, 300, 400, 500, 1500 and 2000
  1. From the map screen press Menu and select View
  2. Select profiles and press Enter
  3. Select hiking and press Enter
  4. Press the Page/Go To key once and scroll down to select time zone
  5. Press Enter to select your time zone and Enter again to confirm.
  6. Press ESC repeatedly until you return to the map screen.
Note: Make sure Daylight Savings is adjusted accordingly. For Vehicle Navigation series Maestro and RoadMate 1200-1430
  1. From the map screen select Menu
  2. Select User Options
  3. Select System Settings
  4. Select Time Zone
Aug 29, 2008 | Magellan RoadMate 2200T GPS Receiver
Magellan Maestro 3200
How do I erase adresses that were put in the Magellan 3200
Dec 30, 2007 | Magellan Maestro 4040 GPS Receiver
GPS Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
