Question about HP iPAQ HX4700 Pocket PC
4700 photos no longer scrolling on screen saver
My IPAQ was scrolling through all my photos as a screen saver previously but for some reason it has stopped and goes to blank screen now. If i enter dockware drop down menu the "Show pictures" option is ticked. If i deselect it and reselect the pictures re-appear but only until the next activation of the unit and then it defaults back to blank screen again next time around...strange???
  • 450 Answers
You may want to change the time after which the IPAQ turns itself off. If this time is too short, then Dockware may not be activated.
Posted on Sep 08, 2005
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
IPAQ 4700 hard resetting on its own.
I also own an ipaq 4700 and experienced the same problem. Even after reloading the OS I continued to have this problem. I did buy it refurbished but I fear this may be a common hardware problem. From my research it would appear the battery is the most likely culprit, I have not tried replacing mine but it may be worth a shot, if nothing else you have an extra battery which means less time at the charger :D
Apr 16, 2009 | HP iPAQ HX4700 Pocket PC
Hp 4700 ipaq does not display properly
Take a firmware update to your Hp 4700
Mar 26, 2009 | HP iPAQ HX4700 Pocket PC
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
HP Ipaq 4700 stylus problem
ask HP yet, we are not HP , sorry and this thing is legacy retired product , what good is it?
here is the real HP forum
see if you can get tears there.
Dec 02, 2017 | HP iPAQ HX4700 Pocket PC
Printed manuals and CDROM for HP Ipaq 4700
I found the right place to post this request so I have transferred it.
Feb 24, 2008 | HP iPAQ H4150 Pocket PC
Media Player 9 on ipaq hx4700
The 4700 has a 480 x 640 pixels display and WMP9 will not compensate for the smaller resolution videosthus the less than full screen size play back on video with less than the 480 x 640 pixels size resolution. There is a program that will play the smaller res. videos in full screen on your PDA try TCPMP its free, go here:
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ hx4700 Pocket PC
if your PCs connect wireleslly, then I assume you have set up a home network with a router/modem. Sometimes the modem comes combined with a router. If this is the case, then the 4700 has all you need to connect it to this network and access your emails and internet. This is an example of my setup with my 4700... Go to Start > Settings > Connections > Connections > click on Advanced tab at the bottom click on "Select Networks" button Both entries on this page should be set to "My Work Network". Click "OK" > "OK" back to Settings screen. Go back to Today Screen. Now click on the iPaq Wireless icon at bottom right of this screen. If the WiFi button has an 'x' on it then click it to turn it on. A blue light should now come on at the top of your ipaq to indicate that wifi is on. Click on the 'Settings' button You should be able to see your network on this screen - "Configure Wireless Networks" Networks to access should be set to "All Available" Check the box to 'Automatically connect to non-preferred networks' If the Network is available but not connected, then click on it's name. On this next screen you should select next to 'Connects to' - "The Internet" Then click OK If the Network shows 'Available' and not 'Connected' then click and hold on the name of the network and then you can choose 'Connect' Then under 'Network Adapters', on that screen it should say ... My Network card connects to 'Work"
Sep 07, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
61 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
