Question about Brother Office Equipment & Supplies
Little dots all over page - Brother Office Equipment & Supplies
  • 446 Answers
This could cause by a overtoned developing problem, could be because you might have changed a toner lately? or install a generic one, if you do it may not be compatible and cause problem on your unit.
if yes, clean the affected developing unit, with a vacuum all scattered toner all over, and install the right toner.
Posted on Aug 28, 2008
Riso drum prints extra little black dots on page
The solutions on that problem is in the imaging unit like you just have to clean the lens of the camera since tiny dots are dust that is being scnned by the lens during master making process
May 16, 2013 | Riso RZ220 Duplicator
Xerox 7132 printing dots after 35 pages
Check if it is with just one document or with all documents. Can also be coming from the job and not the printer
Apr 07, 2013 | Xerox WorkCentre 7132 Multifunction Color...
I have a problem with word normal.dot, I think normal.dot file is corrupted is this possible by a virus ?
1. Double click on My Computer.
2. Click on the Tools menu in the top menu bar.
3. Click on Folder Options...
4. Click on the View Tab
5. Click on the little button next to "Show hidden files and folders" (in the Advanced Settings box)
6. Click OK.
7. Double click on Local Disk (C:)
8. Double click on the Documents and Settings folder
9. Double click on the folder with your user name
10. Double click on Application Data. (That folder will be dimmed)
11. Double click on the Microsoft folder.
12. Double click on the Templates folder.
13. Right click on the Normal.dot file and delete it
14. Now you need to hide your hidden folders again
15. Click on the Tools menu in the top menu bar.
16. Click on Folder Options...
17. Click on the View tab.
18. Click on the little button next to "Do not show hidden files and folders" (in the Advanced Settings box)
19. Click on OK.
20. Close all the open windows and you are done!
Every time you open Microsoft Word, you go to a blank page. That blank page is called Normal.dot. If you ever open Microsoft Word, and you don't get a blank page, then your Normal.dot file has somehow been changed. If you have this problem, follow these steps
Jun 13, 2011 | Microsoft Windows Vista Home Basic Edition
Just purchased used. There is no instruction manual. I can only see a little dot of light when looking into the eyepiece. I don't know if all of the part are there....?
All of the Bushnell manuals are on this page.
http://www.opticsplanet.net/bushnell-warranty.html
Look down the page for your telescope. You must insert an eyepiece into the focuser. Do you have any eyepieces?
Oct 05, 2010 | Bushnell Optics
Unwanted 'dots' on printout
There is a dot somewhere on the drum, remove the drum and toner cartridge from the machine, then remove toner from drum. Look at the shiny roll, you can turn it from the black gear on the side. Once you find the dot use a cue tip dipped into little bit of alcohol and clean it off.
Mar 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
Dots appear on printed pages.
dot is due to damage to the drum or fuser roller .. inspect both to find which unit to replace. the spot should be easily found by rotating the units by hand... If this is a copy the dot will be on the scanner glass   good luck
Apr 16, 2009 | Brother HL 5140 Laser Printer
Brother dcp7010 all my printed pages have 4 dots on right hand side how do i get rid
If this 4 dots have equal positions from page 2 page: *replace OPC or replace drum unit
If this 4 dots have non-equal positions from page 2 page:
*do Preventive maintenance for your Brother
Oct 16, 2008 | Brother DCP 7010 Multifunction Laser...
Black spots on my documents Brother HL-1440
Stray dots (on a vertical imaginary line on the page) may not require an expensive drum replacement. In my situation, I simply followed these steps:
(1) Open up the printer, remove the toner-cartridge/drum assembly, and remove the toner cartridge from the drum.
(2) For purposes of reference, place (and center) a sample page of the "offending" output in the bottom of the drum housing, lining up the dots so that the page is turned the way it would have fed through the printer, placing the page generally in front of the shiny green roller surface. Loo, for where any matching black dot or other thing might be sitting on that surface.
(3) Gently roll the green surface's roller with its outside end pegs (without touching the green surface) if and until such a matching dot (or dots) can be found. (Multiple dots might appear along other imaginary verticals on the page, which is to say, additional vertical striping is occurring because there are more instances of "items/dots/garbage" arrayed across the roller on the horizontal, to produce repeat images down the page as the page feeds through the printer.)
(4) Take a Q-tip and very, very, very gently "polish" away the dot(s) you found on the green roller. (I ended up just dabbing the dot I found--which had consistently left a trail of three dots down my pages, in different locations because of the distance the roller traveled relative to the page size--using the absolute least amount moisture to remove it.)
(5) Clean the drum's corona wire by moving the blue plastic slider back and forth, and leave the slider at the far left point.
(6) Reassemble the toner cartridge and the drum and place the assembly back in the printer.
(7) Test.
Worked great for me. Done in around five minutes. No cost, except for the negligible cost of a Q-tip. No time waiting for a new drum to show up, etc.
Oct 17, 2007 | Brother HL 1440 Laser Printer
379 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
