Question about Kenmore Elite 45986 Front Load Washer
F2 problem I have this problem when the cycle reaches 2 minutes it will stop and just flash with the f2 does this mean I need to pull this pump and impeller thing?
    Genius:
  • 1,028 Answers
F2 is usually and indication of drain problems usually something in pump ..have seen impeller on pump shaft come loose and freewheel..remove pump completely 3-4 screws hold pump motor to housing remove them try turning impeller if impeller spins free replace pump ..impeller will usually have some resistance when turned by hand..a free spin on impeller indicates it has come free of motor shaft
Posted on Aug 29, 2008
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
My hot tub pump will not stop running even after it has reached temperature and completed it's cycle. I have a Balboa Instruments control unit. Any suggestions?
sound like you have the filter cycle set to fc means filters all the time try to push temp button and then pump button. in sequence you want it to be f2 means filters 2hrs every 12 hours
Nov 22, 2009 | Sys BALBOA SUV SYS 5.5kW W/ 120V 1.OHP...
What does a code F2 mean on a duet washer
I have the Kenmore HT3 front load washer. It was giving alot of SUDS codes and then it progressed into an F2 code. It was not draining of water and it was tacking three hours to finish the cycle. It would start to spint and stop as it sped up.) I opened the door at an end of a cycle and the clothes were soaked, with floating water. after searching a few blogs, I unplugded it and I pulled it out from the wall about 3 feet. Then I pushed it backward at the top I leaned it against the wall were it was just past balanced, while tilted back. The bottom front panel has three nut screws. I removed them and pulled the panel off. Just center in the lower cabinet is a hose that comes down to a trap. The trap has a screw cap about 3" in diameter. Screw counter clock wise until it comes off. You will see in the housing is a tube aka small handle. Pulling gently I worked this piece out. It was a shovel shaped trap filter with holes in it. Ours had string, foam, screws, rock 3/4" round and sunfloor seeds and a lot of gunk. It was packed full. I cleaned it out and returned everthing as it was. The codes have stopped and it is now working correctly. This is a 10 minute fix. best of luck. Do this when you washer is empty of water not full! :) Best of luck.
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 code... stops part way through cycles.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jun 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F2 is flashing, still in wash cycle
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
Apr 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 & Alarm problem with cloths
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F2 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display. globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check the electrical connections at the pump and make sure the pump is running. globul1a.gif Check the drain pump filter for foreign objects. globul1a.gif If the above does not correct the problem, replace the pump.
These are the possibilities for that error code at one web site:
Press PAUSE/CANCEL twice to clear the display. * Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
F2 is long drain.
Just because it came up doesn't mean there's a problem, it simply means there was a failure during the cycle, if it returns on a regular basis, you have a problem.
F2 error could be caused by the over use of soap, you need to make sure your using 2 tablespoons of HE soap, 1/4 cap at the most.
Over sudsing, could cause the water pump to run longer, the pump is designed for 15 min duty cycle which means, 15 minutes on to 45 minutes off. The computer may sense too much soap, and continue to pump. HE soap will cure that, along with SUD error, possible F9 (overflow condition), you may also notice the timing is wrong, HE soap works well in these machines and F/l washer go hand in hand
if the F2 returns the remove the 3 torx screws from the bottom kick panel, and remove the kick panel, right there in the middle you will see a big round handle, turn it and then slide it out, have some towels ready, there will be some water in there, and check to see if you have any thing in there that will slow water flow, tooth picks and other "floating" items may jam the impeller.
Feb 15, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite HE3 - f2 blinking
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Nov 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t cycle time blinking but nothing happening
remove lower panel reach up to lock area and pull down on tab to release door remove as much water as possible go back to bottom and turn pump clean out to left HAVE PLENTY OF TOWELS HANDY..clean pump trap out and reinstall
Nov 09, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F2 flashing on display screen washer won't continue cycle????
Potential causes
Oct 12, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
548 people viewed this question
Sal De
fordexpert
Robert Rankin
