Question about Amptron Computers & Internet
Amptron PC II - 3100 rev 1.2
I would like to upgrade this computer, can't find specs.
  • Roberta Smith
    Roberta Smith May 11, 2010
    What types of upgrades did you have in mind. even more helpful would be the number on the motherboard.
    Robert
Good morning Bunnydawg,
Thank you for responding. PcII-3100 Rev. 1.2 is the information on the motherboard. the processor is: the intel Pentium II with MMx Technolgy 80523pr350512 SL 256 Y9060296-0287. The memory is : SDRAM PC100,DIMM,128m,3.3
I would like to upgrade to windows XP, not sure on what upgrades to do. Can't find specs on this mobo. Help!
Thanks any help would be greatly appreciated. BID121
Posted on Aug 28, 2008
2001 buick century torque prints for haeds on up
the 3100 specs
Type: Bolt Dim: Length: Head: Hexagon Grade: 37 Ft-Lbs 444 In-Lbs 50.17 N-m Connects: Cylinder Head To Engine Block Years: 1998-2001 Vote Record: Vote Note: 3100 - Head Bolts - 2 Steps: 37FtLbs; +90deg
12 Ft-Lbs 144 In-Lbs 16.27 N-m Connects: Exhaust Manifold To Cylinder Head Years: All Vote Record: Vote Note: 3100 - Exhaust Manifold to Cylinder Head
Type: Bolt Dim: Length: Head: Hexagon Grade: 9.58 Ft-Lbs 115 In-Lbs 13 N-m Connects: Intake Manifold To Cylinder Head Years: All Vote Record: 0/1(0%) Note: 3100 - Lower Bolts - 2 Steps: 5 FtLbs; 9.58 FtLbs Here are the head bolt torques for a 3.8
37 Ft-Lbs 444 In-Lbs 50.17 N-m Connects: Cylinder Head To Engine Block Years: 1999-2005 Vote Record: Vote Note: 3800 II - 2 Steps: 37FtLbs; +120deg
13 Ft-Lbs 156 In-Lbs 17.63 N-m Connects: Exhaust Manifold To Cylinder Head Years: 1999-2005 Vote Record: Vote Note: 3800 II - Exhaust Manifold to Cylinder Head - NOT FRONT 2
7.42 Ft-Lbs 89 In-Lbs 10.06 N-m Connects: Fuel Rail To Intake Manifold Years: All Vote Record: Vote Note: 3800 II - Fuel Rail Mounting Bolts 2.25 Ft-Lbs 27 In-Lbs 3.05 N-m Connects: Idle Air Control Valve To Throttle Body Years: All Vote Record: Vote Note: 3800 II - Idle Air Control Valve to Throttle Body Type: Bolt Dim: Length: Head: Nut Grade: 11 Ft-Lbs 132 In-Lbs 14.92 N-m Connects: Intake Manifold To Cylinder Head Years: All Vote Record: Vote Note: 3800 II - Intake Manifold to Cylinder Head Bolts/Nuts
7.42 Ft-Lbs 89 In-Lbs 10.06 N-m Connects: Intake Manifold Plenum To Intake Manifold Years: All Vote Record: Vote Note: 3800 II - Intake Manifold (Upper) to Lower Manifold Type: Bolt Dim: Length: Head: Hexagon Grade: 14 Ft-Lbs 168 In-Lbs 18.98 N-m Connects: Knock Sensor To Cylinder Head Years: All Vote Record: Vote Note: 3800 II - Knock Sensor
Jul 24, 2016 | 2001 Buick Century
Dell dimension maximum cpu upgrade
This desktop has a motherboard in it that has an intel LGA 775 processor socket in it. From the spec's I found the cpu that ships with the system should be able to scale up to 3.5 Ghz. But you should be able to replace it with any Pentium 4 that fits into an LGA 775 socket.
Nov 29, 2012 | Dell Dimension 3100 PC Desktop
I have a Gateway zx4351. Can I upgrade to a dedicated video card from my GeForce 9200?
It is possible... Yes.
Is it worth it... Maybe the ram upgrade to 8GB is worth the money...
Also, some all in one computers are very hard to even figure out how to open. You better make sure you can do it before you try. You also might want to check if opening the case voids your warranty too.
Specs:
http://support.gateway.com/s/desktop/2010/gateway/zx/zx4351/ZX4351sp2.shtml
Jun 19, 2012 | Gateway 500XL PC Desktop
Amptron a170e1-02 Monitor specs
Go to manufacturers website and download users manual for monitor specifications
Apr 03, 2012 | Computers & Internet
Computer is too slow
Reinstall Windows and later install less programs.
Jul 18, 2010 | Dell Dimension 3100 PC Desktop
Memory upgrade problem
That does not sound like a problem with a memory upgrade. try to unistall McAfee and reinstall. The memory change may have threw McAfee off. Make sure that the ram is also in the right bus. Buses are color coded and the 2 ram stick have to go into the same bus. this can cause problems
Jan 15, 2009 | Dell Dimension 3100 PC Desktop
UpGrade
download cpuz it will tell your specs
Oct 18, 2008 | E-Machines eMachines Desktop PC
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
How do i upgrade memory acer aspire 3100
How much memory you have right now, this model does have capability of upto 1GB , If you are running Vista on your computer try inserting a blank 1GB USB flash drive, and You will have 1 GB additional memory.
Jun 29, 2008 | Acer Computers & Internet
Which RAM to use for Soltek SL-75DRV/-v
Leif: The difference in the numbers (2700 versus 3200) is speed rating-- basically, the higher the number the faster the RAM. Your computer is currently using 2700, so it's safe to use 3200, it's just faster than is currently used/specified.
Your computer is a Socket A - AMD Via-based board, so it is likely the motherboard will accept 1 GB memory modules. With three slots open, you would want to buy 2, 1-GB modules for best results. At current pricing, that would cost about $100. 2- 512MB modules would be next-best and around $55. Be sure to place the two modules in the slots next to each other, and closest to the processor for best results.
Nov 22, 2007 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
81 people viewed this question
Top Amptron Computers & Internet Experts
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
