Question about Intel D845GRG Motherboard
Gateway PC I bought a Gateway PC and installed a hard drive that I had previously in it but the prompt says that it does not detect the hard drive nor the disk drive which are both in good shape. There is no power detected to these devices when I power up. Could this be proof that the motherboard needs to be replaced?
Mera land le madhachod koi kaam ka nahi tera sites....
computerguru
Posted on Nov 07, 2008
Rtgrgrtg
Posted on Oct 29, 2008
  • 749 Answers
Sounds more like a power supply issue as these are both powered directly by the power supply. check your power cables inside the case and make sure you didnt bump them or leave them disconnected when you installed the harddrive.
Posted on Oct 08, 2008
Gateway mp8708 s/n t23691006485 showing disk error won't boot just shows disk error help me
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 20, 2012 | Gateway Computers & Internet
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
Black screen with cursor on the left upper corner blinking, does not load windows
1. Boot from the Windows install disk that came with computer
2. After choosing your language, choose the "Repair your computer" option on the "install now" screen
3. Optional step: if you need special drivers to access your hard drives (SCSI, etc), follow the "load drivers" onscreen instructions to read them from an external source.
4. When prompted, choose the "System restore" option
5. Choose one of the previous restore points (I chose the second one down on mine just to be sure)
6. The system will roll back installs to that restore point; reboot only when prompted
I hope this is helpful to you.
Jan 10, 2011 | Gateway 500 XL PC Desktop
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Howvto replace hard T-1616
1ºst is the Hard Drive making funny noise?, like Scrathing? Has the Bios dont Detect? It´s very hot in Hard Disk? If not. you have a serious Virus Problem, instaled in the Bios Hard Disk. Just Low Level Disk format, and use the Hard Disk Utils for HardDisk Company. 90% of Hard Disk Problems is Virus Problems
Nov 21, 2009 | Gateway Computers & Internet
What does ' a disk read error occurred press ctr alt del to restart, everytime i do it it gives me the same error??
You could have a hard drive problem. To check the hard drive boot up to the Windows XP cd in repair mode. At the C prompt type: chkdsk /r
This will start a program called Check Disk that will evaluate your hard drive and attempt to fix any errors. it Check Disk is successful it will complete 100% and return to a C prompt. You can then attempt to reboot. If Check Disk finds unrecoverable errors you will need to purchase a new hard drive and rebuild the OS.
Jun 14, 2009 | Gateway MX6453 Notebook
Installed a new hard drive
Well, since the new hard disk is not formatted, and there is nothing currently on it, you will not get a dos prompt or an operating system detected. What you need to do is insert your Windows XP disk, then reboot the machine. When you see the HP screen, tap the F12 key, which will take you to a boot menu. On the boot menu, choose your CD drive, then the computer will boot from the windows disk. From there, just format your disk, and install Windows.
Apr 14, 2009 | HP Pavilion 520c PC Desktop
My Gateway Crashed And I Took The Hard Drive Out And Put It In Another Computer And Upgraded Windows Me To Win Xp And Now When I Turn It On The Best I Get Is A "Failure To Boot" Message. What Do I Do?
Do a Repair Install using the WinXP CD.
Don't go into the Recovery Consol, but continue with installing Windows. Eventually it will detect a previous installation and offer an option to repair it. It it does not detect your previous installation, quit the installation or you will lose your data.
This should fix the problem which is likely that the boot sector on the hard drive is corrupt without affecting your data.
Mar 05, 2009 | Computers & Internet
Intel D845GRG Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
