Question about Microwave Ovens
Amana ACO1860AS microwave
Have this model and the touchpad stopped working. Just prior both light bulbs above stove burned out (at different times). i just waited a bit to replace them. I read someplace that that could cause this problem - I went out today to buy replacements - installed them - unplugged unit for about 5 min and replugged it in, but same problem.
Any suggestions? microsyskl@yahoo.com
  • Microwave Ovens Master
  • 9,098 Answers
(I'm answering this directly via e-mail, too, but would still appreciate your kind rating)
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 01, 2008
  • William Miller
    William Miller Sep 13, 2008
    Just finished repairing one of these today for a different problem.
    Please le me know if I can be of service.
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
My Amana Radarange over the stove microwave started to omit a "burnt rubber" smell and stopped defrosting or heating anything all of a sudden. Model #MVH15W. Still works otherwise, lights on...
You're describing a common smell that goes along with a magnetron tube that has failed. The magnetron tube makes the microwaves, and will eventually fail if you keep a microwave long enough. They can fail in a couple of different ways, and one is to short out accompanied by that burning smell. It's probably not worth trying to repair your oven because of its age. I don't believe the magnetron is available any longer. If it is, it will be costly, and replacing the tube is best left to a professional because of safety concerns. Your most economical choice would be to replace the oven.
Feb 28, 2011 | Amana Microwave Ovens
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Amana Radarange model ACO1860AS- does not work at all
That model would be ACO1860AS-, not AC01860AS by the way. That will make it easier to find info on it.
Chances are the heat from the stove top (when used without having the hood vent exhaust fan on as required) has blown the bottom thermostat/thermistor (called "Thrmst-fix" on the part list) or maybe the oven cavity thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Your owner's manual includes the installation instructions and can be downloaded here.
Jan 30, 2009 | Tappan TMT104E1 Microwave Oven
Bulbs UNDER the microwave burned out; new bulbs don't work
i know this is going to make no sense . but in my samsung service cd it is in BOLD PRINT YOU MUST DISCONECT POWER BEFORE REPLACEING BULBS , OR DAMAGE TO TIMER WILL RESULT ! the first time you changed them did you disconect power ? if not , your board might be toast , $$$$$$$$$
Jan 24, 2009 | Samsung SMH7174BC Microwave Oven
Microwave oven ACO1860AS
just aquired one just like it for free. they said no heat. took the outer cover off. about 12 screws. pull the main fuse and test it with a continuity tester.thats probably not it if the lights work. its either the magnatron (toshiba 2m248j(gs) or replacement part amana 8205460. mine was a coroded magnatron connection.unplugged it and pluged it back in. heats fine now. if you left it on with nothing in it for any length of time you blew the magnetron. universal magnatron replacements on ebay are $25. 4 screws and a 2 prong connector.
Aug 11, 2008 | Amana ACO1860 Microwave Oven
Microwave Ovens Logo
216 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
