Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirpool Ultimate Care II -- No Drain/No Spin
Mike: I took a "guests" advice first which was that it was a lid switch. I stuck a clothespin in the hole and then leaned the lid on it and suddenly it was draining and spinning. Do you know if this is a part I can purchase and have my husband install, or do I need a repairman. The machine is about 8 years old and I'm not prepared YET to buy a new one. Any advice you can offer would be great. Thanks! Diane B.
    Genius:
  • 1,028 Answers
Not a major project..remove 2 screws in rear of console lift and roll console back ..remove plug in cabinet to switch and pop clips out each corner ..cabinet can then be lened forward and removed allowing access to switch
Posted on Aug 30, 2008
Our ultimate care ii is not working properly. it
the lid switch is broken,open and close the lid if you don't hear a click that's a sure sign the lid switch is broke,try sticking a pen or something in where the switch is you might get it to spin and drain but you gotta change out the lid switch
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Ultimate Care II - Top loading washer The water will not drain prior to the spin cylce - Please help
The lid switch is the most probablle cause for this problem.Check the lid switch lift the lid and close it if you cant hear a click replace the lid switch.
Dec 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
What happens if the lid switch is laying there? Stupid I know?
Hello, if the lid switch becomes disconnected or moves from where it should be you machine will not spin or drain, some machines will not agitate either, The lid switch is basically there for your safety so you don't open it while it is in a high speed spin. Hope this helps. Mike
Oct 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin, won't drain
Hi...
If your washer does not drain, you need to check this:
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
If it does not spin check also this:
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin or drain
I took the easy advice first. One guest said it was the lid switch. So I opened the lid and put a clothespin in the hole and then leaned the lid on it and guess what??? It began to drain and spin perfectly! PHEW... that saved me some time and money till I can get the switch replaced. THANK YOU "guest" from August 11th!!!
Aug 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal De
