Question about Toshiba e750 Pocket PC
Maximum memory?
What is the largest SD and CF memory card that can be used in the e750 wifi?
    Master:
  • 903 Answers
My last infos was that you could use Secure Digital Memory Card up to 512MB (PX1121E-1NME) and Compact Flash Memory Card up to 1GB (PX1076E-1NME).
Posted on Sep 08, 2005
    Master:
  • 903 Answers
How much I know there are no limits. I have information that with 1GB Card there are no problems. It can be that if you use Card with high memory capacity PDA can read data somewhat more slowly.
SOURCE:
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
The following link describes the maximum SD card size for your camera.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/BenQ/BenQ+DC+E53_Memory_Cards
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Jan 05, 2011 | BenQ DC E53 Digital Camera
What is the largest mb sd card the kodak dcs pro 14n will read ??
Hello!
Seems the DCS PRO/n do not handel SD cards with HC capabilitys. So the largest SD cars that there is i 4GB. Problems is to find such a card.
In reallity 2GB is possible.
I recomend You to obtain a CF card instead. I use a 16GB CF and it work like a charm.
I suppose the DCS 14/n work the same way.
Regards PeO
Sep 25, 2010 | Kodak DCS 14n Digital Camera
Older VHS-C Palmcorder Memory cards size recognition
Dear Sir,
Yes all noted on your SD/CF card question, well this was a very good question for me simply because I too have had this same problem with my own Sony Digital 340 movie camera.
My camera come with a 128 mb SD card, and like a fool I went last week and bought a 2 g card, and my camera just cannot see it let alone use it, and I now find that camera's before 2004 cannot see any g cards, and like me you are stuck with small max of 128 m because the camera hard-ware is old tec stuff, sad I think my friend, but that's it.
Take care,
from
David
Jun 03, 2010 | Panasonic Palmcorder PV-L452 Camcorder
Memory card type for Samsung S860
The S860 can use any SD or SDHC card.
Jan 13, 2010 | Samsung S860 Digital Camera
What memory cards are compatible
Probably most of the small memory cards(sd, mini sd, micro sd-some may need an adaptor, sometimes included with your purchase)
Maybe, CF memory card, but most manufacturers tend not to include this format. Most definitely, you must have usb memory slot.
May 25, 2009 | HP Compaq Presario SR2011WM PC Desktop
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
SD wifi
I would rather go for CF wifi card, because Panasonic doesn't states that this one has SDIO type slot. If you use CF slot you will have to find WIFI card cover - it's different one - it will allow to close top cover with the card inside.
There was also two models:
  • CF-P1P1CDZ6J - Bluetooth / wireless LAN built-in
  • CF-P1P1CZZ6J - Built-in wireless LAN-model
Apr 28, 2008 | Panasonic Toughbook CF-P1
SD GPS
I have read some Information about Toshiba PDAs. There is a technique called SD™ IO card. In the technical specifications I found this Info: 1 x SD™ card slot (supports SD™ memory card, SD™ IO card, MultiMedia card) So when SD™ IO card is the same as Bsquare SDIO Now! tecnique...
Sep 08, 2005 | Toshiba e750 Pocket PC
Sdio GPS
as far as I know the e750 supports the SD-Card I/O standard. You can check your system seettings, go to START - SETTINGS - SYSTEM - SYSTEM INFORMATION - DRIVERS There should be seen the SD/MMC Host driver, the SD/MMC Memory Driver and CF Card driver. Also if the gps card needs a driver, it should be installed also! Perhaps a system reset helps you in the end!
Toshiba e750 Pocket PC Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
