Question about HP iPAQ H5450 Pocket PC
My H5450 won't charge!
Could someone please help me with this frustrating problem? My 5450 is dead and I'm trying to revive it, in fact I'm thinking about CPRing right out the damn window!!! Last week it died and I couldn't recharge it. While on the cradle I noticed it didn't show the charge light flashing. I tried doing a hard reset over the next couple of days with no luck! I figured, because it is about 3 years old, I thought it was the battery, so I bought a new one&.. Hey it worked! But I noticed the charge light still wasn't going. Now I'll mention here the unit could synch ok but didn't charge. The following morning the battery was dead flat. Now I have 2 batteries and a PDA that doesn't work. I spoke to the HP rep who referred me to take it to an HP service centre&.. After ringing the service centre, they told me it was the AC power cable&. Well after going to 5 stores to buy one, I find that didnt work either. Now I have a PDA, 2 batteries and a AC power cable that doesnt work!!! Can anybody shed any light on my problem?
    Master:
  • 450 Answers
When you charge up your iPaq, do you use the cradle, or do you use the AC-adapter with the little iPaq power converter that came with the iPaq? Try both, and see if it charges up your pda. Try and borrow an iPaq car-charger and see if it charges up that way (the ones that do not need the iPaq power converter). If you are lucky enough to power up the iPaq even for 2 minutes, enable USB fast charging in the SETTING -> BATTERY. Your USB-data-cable or cradle will then be able to charge it up that way...
Posted on Sep 08, 2005
How can i fix my cell phone battery?
if your battery is dead you can revive it by voltage regulator to shock the battery to revive it and need to charge it to gain back its life,,, charging the dad battery cannot help to revive it, 100 percent on that,,
Nov 07, 2012 | Nokia Cell Phones
Tip
What To Do When Your Phone Does Not Turn On
The simplest reason causing a phone not turn on is a dead or drained battery. It happens when the phone gets immersed in water, dropped or allowed to fully drain the battery. The symptom is phone not turning on and not charging the battery. When that happens, make sure first that the battery is not just dead or drained before you send the phone to the service center for repair or before you buy a new battery. You may decide to send it right away only to find out the battery is simply dead/drained or buy a new battery only to find out the phone is dead.
The first thing you can do is borrow a friend’s known good battery similar to yours and try it in your phone. If the phone turns on, you are pretty sure your battery is dead or drained; otherwise, it's time to send it for repair.
When it is verified that the battery is dead or drained or if you don’t have someone to borrow from, try to revive the battery before you buy a new one. You just need a 9-volt battery, a 6-12 volt power supply, or a DC adaptor (6 or 9 volts) and a set of wires.
Connect the set of wires to the terminals of the 9-volt battery, power supply, or DC adaptor whichever is available.
Look for the polarity markings on your battery and connect the other ends of the wires to the battery terminals in the same polarity as the source above. The positive terminal is marked (+) while the negative is marked (-). Do this for 10 to 60 seconds or until the battery gets slightly warm. Do not use this procedure to fully charge the battery.
Insert the revived battery in your phone and charge it until it is fully charged. If the battery works well and does not discharge easily, you don't have to replace it.
In the event that it is not verified whether the phone still turns on or not using a known good battery and the battery is revived but the phone is still not charging the battery, the phone is dead; send it to the service center for repair.
on Dec 06, 2009 | Cell Phones
My phone battery got completely dead,when i charged it i put it on and saw the welcome g1 tmobile and android after which it stays blank.so i dont know whats going on?please i need help
The battery needs to be revived when it is completely drained or when it is dead because the phone will not be able to charge it. For instructions on how to revive battery, check it here.
Apr 06, 2010 | HTC G1 Smartphone
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
Trouble charging h5450
try wrapping the cord around the pda
Jun 08, 2009 | HP iPAQ H5450 Pocket PC
Can't reset!
open it, remove 6 screw behind. remove rom batteries for a sec. and plug it on the same place. work . reset flash
Jun 01, 2009 | HP iPAQ H5450 Pocket PC
Syncronising with pc
i have a 5450 , it will recognise and find my wifi but will not connect to it . any ideas , thanks in advance
Apr 12, 2008 | HP iPAQ H5450 Pocket PC
My ipaq 5450 is not charging
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Oct 20, 2007 | HP iPAQ H5450 Pocket PC
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
HP 5450 screen not responding
try holding the stylus in the soft reset hole for about 5 seconds.
Sep 07, 2005 | HP iPAQ H5450 Pocket PC
HP iPAQ H5450 Pocket PC Logo
366 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
