I believe that you likely have a defective dispenser switch located at part location #72 in photo=> HERE This is that part number=> WR23X10224 Micro SwitchI'm here should you have question, Thanks, Sea Breeze
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Check to see if the condenser fan in the rear of the fridge towards the bottom isn't hitting anything. If its inside the fridge it might be ice built up around the evaporator fan.
I have one the same model It done that about a month after I got it.
1995 Year I took of the left top corner the wires that make it work are in it. I wiggeled the wires around untill it started working and folded a card broad and put in it to hold the wires the way I wanted then put the cover back still works to this day.
Worked for me, Thank You,
