Question about Samsung SGH-t219 Cellular Phone
Samsung T219 won't charge
I have had my phone for less than a year and recently it has decided that it doesn't want to charge. My battery is good and I bought another charger to try. That didn't work. It seems as if the port where the plug goes in is bad. Does anyone have any solutions or has anyone had the same problem? I haven't dropped my phone or got it wet. Any help would be greatly appreciated.
Thanks!
  • Cathy VanHouten Oct 18, 2008
    I have a brand new t-219,,, it won't charge
    I just bought a new t-219, before the battery went dead after using it for the first time, I plugged it in to charge. Isn't it suppsed to say it's charging? Well, regardless, it never would charge and when I open it, the phone just turns off. THX
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have the charging port service or rplaced.
Posted on Aug 30, 2008
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 26, 2012 | Motorola Mobility RAZR V3
Hardware
Nov 24, 2011 | Nokia 5530 XpressMusic Smartphone
When i pull out the power cord on my N150 plus the comp crashes,even though the battery is saying 100 per cent..any idea?
A lot of times this happens when the battery has gone bad and needs to be replaced. It might say 100%, but due to use (and sometimes just due to a faulty battery) the battery will charge less and less and eventually won't hold a charge at all. For example, when I first got my laptop a year and a half ago, I could get almost six hours out of a charge. Now I get almost twenty minutes. Unfortunately, I would say you need a battery. You can get one either from samsung (though you may have to call them, I couldn't find your battery on the site), Newegg.com, or ebay.com.
Some good tips for handling your new battery. First, if the computer's plugged in, remove the battery. Put it back in before you unplug it. This will prevent long-term wear on your battery. Secondly, it's good to regularly (I'd say yearly or so) let your computer "die" on battery (run it until the battery dies), then charge it completely THREE TIMES. This will "cycle" your battery. They say that with the newer batteries used nowadays this isn't an issue, because the new type of battery doesn't create the crystals like the older type does, but it can't hurt anything and I've noticed a difference when I do it.
I'm sorry about the bad news, but hopefully this will help!
Aug 22, 2011 | Samsung N150 (36725723009) Netbook
Hi. I have a prblm in Samsung s5620 monte. The prblm is that my phone showing the charge but it not getting charge. What should i do?
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Samsung Cell Phones
I have a problem in Samsung omnia B 7610.When I plug in the charger to power source it displayed the battery is full.When I plug out the battery is low and uncharged.Pl help
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Samsung Omnia Cell Phone
My Samsung phone has no power, won't accept a
The battery is most likely at fault, though if a different battery still doesn't work, there's probably something else to blame.
May 20, 2011 | Samsung Cell Phones
We have a samsung sgh-t219. The phone states that emergency calls only. We cannot make any calls. How can we fix it?
If you are trying to use a SIM card in your phone and getting a message like "Enter Subsidy Code", "Incorrect SIM Card", "SIM not provisioned" , "Emergency Calls Only" or similar messages, then you need an unlock code for your mobile phone. You can get Samsung SGH-T219 Unlock Code from the network provider, they will provide a code with easy to follow instructions on how to unlock your phone. You may check Samsung Unlock Code site, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only.
Hope this is helpful.
Thanks.
Mar 08, 2011 | Samsung SGH-t219 Cellular Phone
Samsung SGH-t219 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
