Question about Pentax *ist D Digital Camera
Battery problem when on computer
Just experienced a problem when connected the computer with the *ist D. Using the original crv3 batteries (taken about 400 shots) I connected the *ist D to the computer (with battery grip on) and the battery indicator depleted light flashed on the screen of the camera and the camera shut down. This was a surprise as the batteries had only taken about 400 shots and I had the battery grip on which had a set of NiMH almost fully charged in it. With the battery grip on I would have thought the camera would use it to power the camera to the computer. I removed the battery grip and inserted a set of charged Nmih batteries into the camera and then the camera worked when connested to the computer. I thought the crv3 must be dead after all, so I checked them with the volt meter and they had 2.84v. This should be enough to run the camera. I checked the fully charged NiMH and they only had 1.315v (2.63v in series) which is less than the crv3. Hmmm. I removed the NiMH from the camera and reinserted the crv3's and lo and behold now the camera works when connected to the computer but without the battery grip. So the camera works with the crv3's at 2.84v but not with battery grip installed with the NiMH batteries. My findings are as follows when connected to the computer: Without battery grip connected: 1) camera works with the crv3 2) camera DOES work with almost fully charged 1.315v (2.63v in series) NiMH With battery grip connected with almost fully charged 1.315v (2.63v in series) NiMH: 1) camera doesn't work with crv3 in camera with NiMH in the battery grip 2) camera doesn't work with NiMH in both camera and battery grip. Now the camera+battery grip did work previously with fully charged NiMH so they musn't take much to drain them past the point of not working when connected to the computer with the battery grip. They still work perfectly well when used for normal shooting just not when connected to the computer at the present charge amount. There must be something about the battery grip that plays havoc with the way the camera reads the amount of power left in the battery as it is OK when the NiMH's are fully charged but not much takes to drain them past that point. Has anybody had this happen?
    Master:
  • 542 Answers
There are several reasons NOT to use the camera for that purpose, but if you really insist, you should get the AC adapter. I got mine at the same time I got the camera, for various reasons, including shooting in studio-like conditions. Beside the rapid battery consumption you've already discovered, there are other disadvantages. Remember that the USB connection carries power. There is a very remote but significant chance that a one-in-a-million malfunction could damage the camera, the card or both. It sounds far-fetched, but if there was such a malfunction, your camera could get fried. Image files in the card could get corrupted or overwritten in such an unlikely event. If nothing else, plugging and unplugging the cable eventually wears out the jacks in the camera, and that could be a factor when you sell the camera down the road. Anyone who's been shooting long enough has seen a flash connector on a camera body wear out or break. Same principle. Heaven forbid your batteries should give up the ghost during the process of updating the firmware! The USB connection is provided as a convenience. I'd use it as a last resort only, and so far I haven't had to. A FireWire reader works much faster, better and safer.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
I won't go into detail because I remember there were posts earlier in the year about this. You are right that there seems to be a problem in the battery meter when it comes to the BGI grip (which is never off my camera mainly because I believe it improves the handling generally but of course also for portrait shots you can't beat it) but isn't always consistent. Battery problems really stopped the day my USB2 card reader arrived as that is all I use now. The other issue you may come accross (and I am not sure if it relates to NiMH only) and has been in posts before is the sudden shutdown when the batteries appear exhausted. You might not be at that stage on your CRV3s (which I can atest have an amazing life). The meter says they are full, you might get a couple of shots showing half life left then bam, the *istD shuts down. This may also have something to do with the battery grip too but not sure.
    Master:
  • 542 Answers
The cable connector on the *istD looks fairly flimsy to me and I am willing to bet it is not designed nor will it last as many insertion cycles as the CF card socket, also the CF card is much more tightly aligned less chance to damage contacts by inserting at an angle, near impossible. Any card reader is faster that using the cable, the cable is only USB1. You say you are lazy, but gee whiz you must be vey patient waiting for images to download via the cable at USB1 rates.
SOURCE:
My Kodak ZD710 Will only let me take about 11 pics and the batteries go dead, I have used the CRV3 battery pack
Welcome to FixYa.
Kodak lithium digital camera battery CRV3 (non-rechargable) approximately can take pictures up to 500 pictures. However, actual life may vary based on the usage.
How to extend your battery life?
1. Use power saving features (using a power saving modes). Limit activites such as reviewing pictures/videos on the LCD.
2. Dirt on the battery contacts can affect battery life. Wipe the contacts with clean,dry cloth before loading the battery in the camera.
3. Battery performance is reduced at temperatures below 41 F(5 degree celcius). When using your camera in cold weather, keep spare batteries warm. Do not discard cold batteries; when they return to room temperature, they may be usable.
Please let me know if you have any questions and if this solution was helpful.
Thank you for using FixYa.
Apr 14, 2011 | Kodak EasyShare ZD710 Digital Camera
I would like to know if I can use Kodak CRV3 or another brand of batteries in the Olympus camera. Are all CRV3 batteries interchangeable?
Yes, they're supposed to be interchangeable. The name CRV3 designates size, voltage, and polarity of the battery.
Oct 10, 2010 | Olympus Camedia C-4000 Zoom Digital Camera
Can i use regular batteries and not rechargeable batteries on my kodak cx4310?
Yes, 2 AA batteries. Just insert them correctly.
They don't last as long as the CRV3 lithium battery pack though
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I bought the CRV3 battery and charger at Radio Shack and love it.
Bought it 3 years ago, still using the same battery after taking 1,000's of pics. I also keep a pair of regular AA's as a back up when I'm away from home
Dec 22, 2009 | Kodak EasyShare CX4310 Digital Camera
How long should a crv3 battery last?
I use crv3 batteries in my Pentax istD. Believe it or not, they last over a year! Keep in mind that the simple act of testing the voltage of a crv3 will shorten its life. Have you tried cleaning the battery contacts in the camera with a cotton swab lightly dampened with rubbing alcohol? Sometimes, an invisible film on the contacts forms and gives a false reading of battery life.
Dec 08, 2009 | Pentax Optio S60 Digital Camera
Camera powers on, then powers off
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Battery support : KAA2HR,CRV3, 2xAA Ni-MH and 2xAA Lithium-Ion
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 12, 2009 | Kodak EasyShare Z710 Digital Camera
Camera powers on, then powers off. New batteries
Remove the battery
Contact KODAK:
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
Oct 26, 2009 | Kodak EasyShare C653 Digital Camera
Will CRV3 2.4 v battery work in this camera?
This isn't a definitive answer, but it is an experiential comment. I would never put a lower voltage battery in something that draws power the way a digital camera does. It might not cause any damage, but I'm fairly certain the results would be low flash, slow reads/writes and possibly other issues.
Nov 17, 2008 | Kodak EasyShare Z710 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Pentax *ist D Digital Camera Logo
59 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
