I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
You can take your Stuhrling Original watch to any watch repair shop for repairs. Or you can package it up and send it to: Stuhrling Original, LLC, 449 20th Street, Brooklyn, NY, 11215.
Simultaneously press two buttons. It reset all, you show "Po". Press buton two (down placed) once quickly or more to set 12:00. Press buton 1 for longer as 3 s. You see 59. After watch synchronized if have good connection with sender, if not you must wait or adjust time by "hand". In Poland I must wait for automatic adjusting ca 3-4 hours. Regards
Hi there. I have the same watch and it's easy to set the year function of the watch. There r 5 different control buttons around the watch case. 3 of them is designed to push with a pens point or it's own pushing tool. U ll see the buttons. There r 2 left hand side, 2 right hand side and 1 facing to u when u tut the watch in front of u. It's just under the strap pin. When u find it simply just push it with a pen or with it's specialized tool( if u have one).. I hope this helps. Regards Cihat
mcdevito75 Here, I may be able to help. The Television show shop NBC has features on Stuhrling watches, they may be able to get you in touch with Stuhrling watches, here"s Shop NBC contact info, 1-800-474-6762
this page should help =)
http://www.stuhrling.com/customerservice.cfm
it has all the instructions, simply click 'instrucion manuals' on the left hand side (kind of towards the bottom) of the page =)
