I have a 10 yr old Armstrong AC..today I found that the evaporator coil has a small leak, replacement cost $750. The unit uses R22. The repair company suggested a heat pump, should i decide to replace the entire AC unit. ($3700) Location is Lincoln NE. Repair or Replace?
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
REPLACE IT AND SAVE MORE MONEY ON ELECTRICITY!
IT WILL PAY FOR ITSELF AFTER A COUPLE OF YEARS OF YOUR LOWER ELECTRIC BILLS!!!!!!!!!!!!!!!!!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this appliance is 10 years old or more do not spend any money on it!
The new ones are much more efficient!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
What are the operating pressures on an Armstrong Concept 10 scua24 A/C
Didn't help ya huh Wayne?? We are in the temperature control businesses, temperature is what's important, not pressure. The hotter something is the more pressure it has. On a satisfied home, I will say 75 degrees, your evaporator coil should be around 40 degrees. 40 degrees with r22 is about 65 psi. 40 degrees with 410 is about 125 psi. Head pressure, your condenser temperature, will vary depending on the time of day. The hotter the temperature, the higher the pressure. R22, 200-225-240...R410a, 300-325-350. Keep in mind, the hotter the house, the higher the pressure. Hope this helps!!
Jul 08, 2017 | Heating & Cooling
What is going on with our Goodman unit?
If your going to pay that much just have them put in a new unit. It is not that much more and you can get free financing. All the repairman can do is guess and keep putting in new parts till it works. Had a new unit put in and it still didn't work found out it was a bad thermostat. But at lest we don't have the repair bills or high electric bill anymore so it paid for its self in saved money.
Jul 21, 2014 | Goodman Heating & Cooling
AIR CONDITIONER IS NOT COOLING, USING GAGUE, FOUND BOTH SUCTION AND DISHCHARGE PRESSURE VERY LOW. IT IS R22 4 TONS AC UNIT, SUCTION 10 PSI, DICHARGE 80 PSI. COMPRESSOR AND FAN RUNNING.
there is probably a leak in the systems somewhere, it needs to be inspected for a leak and charged with R-22 for proper cooling.
There is a stop leak for air conditioning systems available to licensed technicians to buy, might work if the leak is very small.
Aug 22, 2011 | Heating & Cooling
My adp coil already failed in my only 2.5 yr. Old Carrier ac unit. I am now looking at an estimated $1500.00 repair. Coil is under warranty so the above cost reflects labor only. Adp serial #7107A07780....
Sorry, I don't have any solution but I'm in the process of replacing my 2 AC systems (4 tons by York). My RUUD dealer has provided RUUD ac and gas furnace with ADP coil and not using RUUD coil. Should I insist on using RUUD coil rather than ADP coil?
Thanks,
Jun 30, 2010 | Heating & Cooling
I have a Bryant split system AC that is 18 years old. We have been away all summer (2 1/2 months), during which time the thermostat was set to 80°F. We live in SE Virginia and summer temps are 80's...
I am a service manager of a richmond va hvac firm and we tell are employess that if a unit is over 15 yrs old and needs over 500 dollors worth of repair to recomennd replacement the reason the leak repair is so much is because the unit has to have all the refrigerant pulled out and a torch is needed to weld the piping back together in some cases if the leak is in the coil heating it can cause other leaks you also have to add driers to the system and then the environmental fees and rules that the epa makes us follow make prices even worse if you do fix it you probally wont even get a warranty on the repair. I would replace the system and also if cost of repairs are a concern ask the company about a 10 yr part and labor warranty
Sep 22, 2009 | Bryant 463AAC008BA Air Conditioner
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
Tube running from AC unit to the house is completely encased in ice. Does this mean the unit is bad ? Or, does this mean there is a freon leak in the tubing ? And, is it cheaper to replace to unit or try...
You either have a refrigerant leak or a dirty inside coil or a slow running inside blower motor.
Set the thermostat for heat and run it until all the ice is thawed. Then check the incoming air side of the coil for lint and dirt. Check the fan motor for proper speed. If you have service gauges your low side pressure should be approximately 68 psi. If lower you have a leak.
Jul 07, 2009 | Carrier 38CKC030 Air Conditioner
I've got a goodman GSC140241AA ac unit (which is
No it should not. If their is a leak and it can be reached the coil should be repairable. Replacing it will require a pro to replace it and recharge system. Not a user friendly item. Also may need a line drier and a vacuum pulled on system. You need a license to handle R22 and this may be an R 410a system which requires special gauges. But I would try to go back to the installer and or Goodman about the leak.
Jun 30, 2009 | Heating & Cooling
R-22 vs R-134A
not a good idea to swap gas coz need to change tx valve and flush system and use polyester oil,cost a lot. ur best options is to repair, pretty sure it can be soldered
Jun 09, 2009 | Heating & Cooling
Carrier evaporator coil
I recently contacted Carrier Corp after our routine annual HVAC check on our residential system indicated that our 4 ton AC unit and 3 ton unit had leaking evaporator coils.
They basically told me to shove it in a very curt letter - In other words even though a leaking evaporator coil is a manufacturing defect they will not offer any financial assistance in replacing the failed evaporator coils.
I spoke to several HVAC engineers and they indicated Carrier has a high percentage of evaporator coils and compressor failures on residental HVAC systems.
The copper wall of the evaporator coil is being drawn thinner than in earlier years and the R22 being acidic slowly eats through the copper tubing.
Evaporator coils should not fail according to the HVAC Engineers if properly manufactured.
The Bear
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
