Question about Car Audio & Video
I installed an after market amp and sub but there is a lot of feedback. How do I bypass the factory limiting system? I have a 2008 accord ex model.
I had to unplug the noise canceling mics. One is located in the dome light fixture in the ceiling up front. You have to take the fixture down and you will see a little black box. The second is located on the back dash. You have to let the back seat down and pop the dash cover and the little box is setting right in the middle of the dash between the rear speakers. Pretty easy to get to both of them...and the feedback noise is gone.
Posted on Sep 18, 2008
    Champion:
  • 232 Answers
INSTALL A HIGH QUALITY CONVERTER IF U ARE USING THE FACTORY RADIO. CHECK YOUR GROUND CONNECTION, INSTALL A BETTER SET OF RCA JACKS. THE NOISE IS BEING PICKED UP THROUGH THE RCA CABLES, RUN THEM ON THE OPPOSITE SIDE OF THE CAR. U CAN ALSO PICK THE NOISE UP FROM THE FUEL PUMP, BUT BETTER RCA WILL FIX MOST PROBLEMS
Posted on Aug 28, 2008
2007 lincoln town car radio
Search the answer on Google.
May 25, 2017 | Lincoln Cars & Trucks
2008 Grizzly 450. Starts and idles fine but at about 10 mph why does it start to cut out like a rev limiter?
2011 grizzly 450 reverse rev limiter - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & Transmission
Mar 11, 2012 - 9 posts
This is a discussion on 2011 grizzly 450 reverse rev limiter within the ... is for earlier model years like 2008. thanks for welcoming to the site :) rev limiter - Yamaha Grizzly ATV Forum
May 23, 2009
Grizzly 700 Reverse rev-limiter Override Mod - Page 3 ...
May 21, 2009
Hitting rev limited/ slow speed.... - Yamaha Grizzly ...
May 20, 2009
reverse rev limiter - override witch bypass - Yamaha ...
Oct 22, 2008
More results from www.grizzlycentral.com
Rev Limiter - GrizzlyOwners.Com Yamaha Grizzly Forums
www.grizzlyowners.com > Grizzly 660 > Modifications
Old 06-30-2008, 10:43 AM Thread Starter. modrak .... jasson450r is offline ... hey guys! how do you do this rev limiter mod on a 06 660 griz? i'm interested in ...
How to bypass reverse switch Grizzly 700(speed limiter ...
? 1:03
https://www.youtube.com/watch?v=l8nn5Z4cuN0
Dec 25, 2015 | Yamaha Motorcycles
2004 GMC Sierra 2500HD with factory Bose stereo system but no on-star, put an aftermarket clarion CD/DVD player in it over 2 years ago i put in the adapter for making the Bose factory system work and
either your connectors need cleaning or maybe a break in the wiring. Is there on spot where both wires come together if so check there.If there is any plugs, pull them apart and clean them with contact cleaner
Dec 15, 2014 | 2004 GMC Sierra 2500HD
What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
I am trying to install a amp and sub in my 08 gmc
dont need a diagram,, most amps have a speaker level input...dont mix this up with line level....connect your wires from back of factory speakers to speaker level input on amp...then if your amp has a low pass switch select lowpass setting now you have punch
Mar 29, 2009 | 2008 GMC Sierra 1500
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
I need to bypass the factory amp in my 97 ford expedition
the amp is in the rear panel pass side if you have the Mach sound system. There are 5 wires going into the amp and 2 going out to the sub.
Light Grn w/ Purple stripe is the 12v power (thick)
Blk w/ Grn Stripe is the grnd (thick)
Drk Grn w/ Pruple stripe is the remote (thin)
Red w/ blk stripe is sub high output +
Drk Brown with Orange is the high output -
Jan 09, 2008 | Car Audio & Video
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
