Question about Dirt Devil Vacuums
Vacuum will not **** even all the way down to the connection where the hose connect to the motor
  • 357 Answers
Try my troubleshooting guide...
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
There may be something stuck inside the fan case. I have other guides which can help you disassemble the Kirby to check for clogs. Hope this helps a bit,
Marci
Posted on Aug 28, 2008
Kenmore Progressive Vacuum electrical issue. My
It could be the wires or switch in the hose and/or the connection between the hose and the vacuum. It could be the power cord or a loose or bad wire inside the canister. It could be the carbon brushes in the motor are worn out. To find a short or electrical problem you need to know how to trace the power flow from the plug and cord all the way to the motor. You can test the wiring in the hose with an electrical tester to see if there is a problem with it before you purchase a new one.
Mar 08, 2017 | Kenmore Vacuums
Tip
Vacuum cleaners: Loss of Suction
A common complaint about vacuum cleaners, regardless of the brand, is loss of suction. The motor runs fine, there seems to be plenty of power, and even some suction, but the vacuum just won't pick up even the lightest of items. There are some very simple checks and fixes to this problem most of the time.
The primary causes are: clogged hose, full bag, leaky hose.
Clogged hose: this is probably the most common cause, and will result in a damaged motor if not cleared.
Check: Remove hose from vacuum and wands. Holding one end, drop a marble or small ball into the opening and allow to roll through. If it doesn't come through the end, then the hose is clogged.
Solution: If you have a canister vacuum with an exhaust port, try connecting the hose to this and turning machine on. If the clog isn't too bad, this may clear it. If not, more extreme measures may be needed.
Never attempt to clear a clog with a coat hanger or similar length of wire, as this could easily puncture the house. Do not use water or high air pressure gun to clear hose.
Full bag: Check bag. Change if necessary. If it seems the bag should hold a little more, well, it's not worth replacing a motor, or the vacuum, trying to find out. Bag pores are easily clogged if the machine is used for cleaning construction areas where sheet rock dust is abundant. Ensure you’re using genuine bags for your machine.
Leaky hose: Over time, hoses suffer from normal wear and tear, and often abuse, resulting in cracks and holes, often too small to notice. Hoses need to be replaced at this time, and this generally results in a dramatic increase in "suction". There simply is no fix for a leaky hose.
Solution: Always store the hose properly to avoid kinking, crimping, smashing, etc. Avoid stepping on the hose, or leaving in an area where it may get stepped on , driven over, or smashed. Avoid pulling the vacuum by the hose, or otherwise stretching/stressing the hose.
on Aug 22, 2010 | Vacuums
Carpet beater not turning on, rest of vacuum ok, reset button down
Is the PN motor not working, or just the brush not spinning. If it's the brush, a new belt is needed.
If the motor isn't working, it could be due to several things. Follow the trouble shooting steps below.
1. Check all connections from hose handle to PN for discoloration. Any parts showing discoloration or melted plastic need to be replaced.
2. Attach PN directly to the hose. If the motor works, there's a problem in the wand wiring/connections.
3. Attach the Sidekick directly to the hose. If it works, but the full sized PN doesn't, there's a problem in the PN. Problems could include: wiring, connections, bad motor, bad switch.
4. If neither Sidekick nor PN work, the problem is likely in the hose. Potential problems include: bad wiring, connections, or bad switch.
5. You can try another hose known to be good to test the PN. If it still doesn't work, the problem could be in the canister itself.
I strongly recommend taking it to an authorized Aerus Electrolux store for diagnosis and repair if needed.
http://www.aerushome.com/storelocator/
Apr 09, 2011 | Electrolux Epic 6500 Vacuum
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Oct 16, 2010 | Electrolux UltraLux 2000 Bagged Canister...
I think my vacuum is even older. It's a tank type. My carpet attachment won't spin where the brush rotates.
The first thing to do is make sure the power nozzle motor is working. If it is, then check the belt by trying to spin the brush. If it spins freely, the belt is broken and needs replaced.
If the power nozzle motor is NOT running, there could be several things.
1. Make sure brush is clear and cleaned of all loose strings, cords, and other foreign matter.
2. Press reset button. Try vacuum again.
If it still doesn't run, ensure all wire connections are tight, and have no indication of arcing, i.e., blackened or burnt connections. Any such connections need replaced.
There could be a broken wire in the hose. Usually the hose will need to be replaced, but occassionally it can be repaired.
Internal wiring worn or broken. Needs repaired/replaced.
All repairs should be done by an authorized Aerus Electrolux service technician at an Aerus store. Check the phone book, or go to the following site to locate the store nearest you.
Oct 13, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Oct 12, 2010 | Electrolux Central Vacuum
After we change the bag, it still gives us a red light
Greetings,
The bag full indicator on most vacuum cleaners is not completley fool proof. Most vacuums will just register a loss of suction, and they will then illuminate the bag full indicator, whether or not the bag is full.
If you've changed the bag, and the machine is still indicating a full bag, then this could mean one of two things.
1. Dirty Filter. According to the part diagram for your vacuum, there is a filter underneath of the vacuum cleaner bag (Bissell Part Number
203-1013) that is there to protect anything from getting into the motor. Since the filter is located before the motor, most refer to this as a pre-motor filter. Sometimes if this filter is really dirty, it can cause the vacuum to loose suction, which will also cause the bag full indicator to incorrectly display. Simply clean this filter by running it under warm water, then allow it to completely dry before replacing it in the vacuum. While the filter is out of the vacuum you can turn it back on and test to see if the light is off now that the filter is out. If the light goes off, then you have found the problem! If the bag full indicator is still on, please see the next possible problem.
2. Clog In the Vacuum. If the vacuum was run with a full bag, and when you removed the bag, the bag was completely jammed full, then your vacuum cleaner may be clogged somewhere. When the bag is packed full of dirt, the vacuum continues to try and put more and more dirt in the bag, even if it's full. Sometimes the dirt will even start accumulating inside the hose as it has no other place to go. The first place you should check is the hole that you connect the bag to. Remove the new bag that you installed and examine the hole that the bag connects to inside the vacuum. Can you see anything stuck here? If yes, do your best to try and dislodge it. If you're not able to visibly see anything here, your clog may be inside the hose, or even in the base of the vacuum.
If you have another vacuum cleaner this will really help you in clearing the clog. With the other vacuum, take the suction hose of the good vacuum, and connect it to the hose on your Bissell (still while the bag is removed, and the bag housing door is open). When you connect the hose of the other vacuum, can you hear a difference in the motor? Does the motor start running at a higher pitch when it's connected to your Bissell? If yes, then you've narrowed it down to a clog in your hose. If you can feel suction from the other vacuum through the hole that the bag connects onto, and the good vacuum's motor doesn't change noise when connected to the Bissell, then your clog is in the bottom section of the vacuum. You can sometimes stretch out the hose of the Bissell while the other vacuum is attached, and this will dislodge the clog.
If you don't have another vacuum, simply remove the hose from the Bissell completely. I believe that there maybe 2 screws that hold this hose onto the back of your Bissell, simply remove these two screws, and remove the hose. An easy way you can clear clogs is to take the hose outside, and use a water hose that has a pressurized nozzle on it, and spray down the hose while holding the hose of your Bissell vertically to allow gravity to work its magic. You can also stretch out the hose of the Bissell to get maximum benefit of gravity and the water.
If the clog is in the lower part of the vacuum, it is usually right at the suction port behind the roller brush. This is the most narrow part of the vacuums suction intake in the lower part of the vacuum, and is prone to clogs. Simply remove the four screws on the bottom of your Bissell to remove the bottom plate. Look behind the roller brush to where the suction port is to see if you can see any clogged debris.
If this doesn't help clear your clog, or fix the bag full indicator, I'd really like to try and diagnosis this further with you. Please just use the Clarification Request or add a comment and explain what happend after trying these things I mentioned above. I'll be more then happy to try and assist your further. I really hope that this was helpful to you. If you found this helpful, please be kind and rate my repair by clicking the thumbs up icon in the review.
Thank you very much,
Chris J.
Mar 21, 2010 | Bissell 3522 PowerForce Bagged Upright...
No sunction from my Hooveer windtunnel vacuum
disconnect the hose from the intake hose on the back its the clear looking hose at the bottom on the back.yes you should feel suction where the bag gets connected the clog is at the bottom.but clean the filters first.your long hose i would take it outside and blow it out with a garden hose.on the bottom where the intake hose is ,take a coat hanger and bend the tip till its rounded so you don't puncture a hole in the hose.just work it down into the tube and se if you can push the clog out the bottom ,you can put your hand over the intake hose where it connects to the long hoseand see if you have suction there,if not then the clog is in your intake hose.if you do then the clog is either in the long hose or the filters
Mar 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Motor goes on and off briefly at regular intervals
Sounds like you may have a bad or loose connection, could be one of wires in the hose to the handle harness or the harness itself may be causing the problem. Also be the motor or relay causing a problem.
Jan 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Suddenly the vacuum won't turn on
Could be a number of reasons, may have a bad cord, If the switch is on the hose, it may have gone bad. Could even be a motor problem. Needs to checked to find the problem.
Mar 13, 2008 | Kenmore 23812 Progressive PowerMate Bagged...
Vacuums Logo
103 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
