Question about Hotpoint Refrigerators
Where do i hook up to charge a hotpoint refrigerator?
  • 1,543 Answers
Charging a refrigerator is NOT a do it yourself job. You should have a tech certified in sealed system repairs do this if needed. Most of the time, consumers think if their refrigerator is not working it needs refrigerant. This is rarely the case. Just why do you think you need to charge a factory sealed system?
Posted on Aug 28, 2008
Hi guys I have hotpoint ff200m fridge freezer. I want to refill gas. But im not too sure which kit i need to buy to do it myself. Can some one help me please thanks
If you mean the refrigerant, I would not recommend it. If the refrigerant has leaked out, there is a leak. The system is contaminated with moisture, and the leak needs to be repaired, filter drier replaced, a vacuum pulled on the system, and a proper charge amount put back in.
Jun 23, 2016 | Hotpoint Refrigerators
Hello, my ice maker is not producing ice, also, there is no water flow for cold water. I checked the water connection, it is charged. Can you recommend a solution pls.? My fridge is a HotPoint...
What about water filter? Is clogged? It is located in fresh food side in back righthand upper corner. also the holder me be bad. You can bypass the filter assembly By going in back of fridge. Hook incoming water to water valve to test. I hope this helps.
Aug 29, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
On my hotpoint frig/freezer, I do not have the water supply line hooked up, but it drips water into the pan of the door dispenser. Any thoughts?
The recess door in ice chute is sticking open. you need to replace the door and door selnoid. This a common problem.
Aug 21, 2011 | Hotpoint HSS25GFP Side by Side...
Just moved, don't know how to hook up water supply to HOTPOINT MODEL # hss25GFPE WW
Find the water valve down by the compressor and connect your water supply, check for leaksthemobilian_52.gif
Apr 11, 2011 | Hotpoint HSS25GFP Side by Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Just hooked up the water line to my hotpoint side by side. There is no water running to the ice maker. The switch is on in the freezer. Is there something else to check?
Did you install the water filter. If you have, possibly it needs replacement. (blocked). Water has to run through filter first.
Nov 11, 2009 | Hotpoint HSS25GFP Side by Side...
I am attempting to change out a circuitboard on a Hotpoint HSS25GFP refrigerator. Is there anything I should be aware of. Thanks
you should ensure you are not staticly charged
this will fry the board in a split second
discharge yourself before you take it out the bag
Oct 03, 2009 | Hotpoint HSS25GFP Side by Side...
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
85 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
