Have just had part problem solved but still stumpd
Just off the line with marked and part one of problem solved now another problem has come up
    Brigadier General:
  • 10,406 Answers
... and your problem is ___________________________ ????
Posted on Dec 03, 2009
I need to know how to line up all the timing marks on 97 Nissan pickup with 2.4l ka24e 12valve engine I'm doing a head job & putting new timing chain oil pump I have never done one before on this type of...
they are pretty much all the same line up your 2 camshaft marks with your crankshaft mark they should all facing the same direction ,if you look on ebay I will bet your problem is solved there , good luck
Sep 21, 2014 | Nissan Cars & Trucks
Printer prints black lines across the page
Clean printer head with clean damp lint free cloth see if that works if not, print heads do wear out sadly.
Jul 21, 2014 | HP LaserJet 1020 Printer
Timing marks 1998 pontiac sunfire
What about the timing marks? They should be lined up with each other. Use a straight edge to line them up. Please be more specific with the question and I can solve your problem.
May 07, 2014 | 1998 Pontiac Sunfire
Timing is off on 2002 XR200R and all I have is an old book. Can you give me the right timing to set?
it depends on your timing problem it could come from your key way. your flywheel could be out. or if you refer to your timing chain it should be marked with a line on it and a marking on your top cog if u can get your piston top dead center and line up both marks you should be on your way thabks hope this solves your problem.. ladjr2
Jul 31, 2011 | 2001 Honda XLR 125 R
My 2000 kia sportege ran hot and stoped . ichanged the head gasket and put on new timing belt . i got good cmpression but no spark to my plugs?
You forgot to line up the timing mark ,get you a manual and lined up the timing marks that will solve your problems ,also check wiring that you reinstaled.
Nov 14, 2010 | 2000 Kia Sportage
Copying problem
Vertical lines on the copy usually indicate a dirty drum or Corona wire. The Corona wire should be cleaned each time you replace the toner cartridge. This is done by moving the Corona tab back and forth across the wire several times to clear it of debris. You may also want to check the drum for debris. Holding the copied page to where it feeds out and lining up the line or mark on the page will give you an idea as to where the dirt may be. Best of luck with your printing issue.
Greg
Nov 04, 2009 | Brother IntelliFAX 2800 Laser Fax
My 98 mazda seems to not be circulating the water correctly and we went througheverything and the water pumps new the head gaskets new theres no leaks. so we are stumpd and really need help
If the coolant isn't flowing with a new water pump; your thermostat isn't working correctly, or your radiator is clogged and not allowing the flow to properly pass through the fins.
Jun 21, 2009 | Mazda 626 Cars & Trucks
Main screen horizontal black lines
look for a button on the remote cont marked n/p or np and press it hope that solves your problem
Jan 16, 2009 | Haier Portable DVD Player PDVD7
Line in
Open control panel > Speech and audio devices > Audio > Sound recording > Advanced Change the device to "Line" just make a tick mark This should solve your problem
Sep 27, 2007 | HP (D7580-60003) Motherboard
Cva-1003
try going to the setup up then changing the aux-1 and aux-2 setting to pal. and make sure they are on. do this by holding down settings button. then press the 1, 2, 3, 4, 5, 6 buttons till you get the right one.
Jun 18, 2007 | Alpine CVA-1003 Car Video Player
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
