Question about Toshiba e740 Pocket PC
Wrong update load sequence ...
I tried to update my 740, I follow the instruction but wrongly I first loaded the boot (boot-e740-1.06.bin) instead of the rom image (nk-e740-1.0624.0410.bin). Now the 740 it resets but it doesn't prompt the message "image download via PPSS" as before... I made a mistake because the program went directly on the folder where is located the boot while the rom file was on the father folder... In that moment, I clicked on that file being sure was the correct one... I was wrong. It seems to work but with no possibility to update it anymore...it's my life !!! What can I do now to fix it? Thank you in advance to anyone can support me.
    Master:
  • 903 Answers
In my opinion you should try to make an update again after resetting of PDA.
Posted on Sep 08, 2005
Why di I geta syntax error wen trying to load voices?
Not sure... try spell check first. Then try updating Garmin Express to the newest version. If that doesn't fix it, you can get the extra voices from the Garmin Garage online instead of Garmin Express:
http://www8.garmin.com/vehicles/voices/#free
Aug 04, 2014 | Garmin nuvi 2455LMT 4.3" GPS Navigator...
Well I tried to reboot my my tashiba laptop and i don't know how to. I have tried the cd but I don't know what to do
To reinstall the computer ..you need either the recovery cd ..or the cd with the operation system in a bootable form ...If you have one of that ..you need to either use the F8 or F11 (depends on the bios model ) to start the boot menu ....and choose to boot from cd ..or to get into bios by pressing del or F2 ..and in there look for the boot sequence ..or boot order...and select the cd /dvd to be the first boot device ..than save the changes with F10 and hit enter ..
After you changed the boot order...restart with the cd in ..and folow instructions on screen for to reinstall or recover the operation system ..
In recover case ...just select the recover and it will go by itself..but in case yopu have a os cd ..you have to press any key to boot from cd when asked..and after that wait untill it loads all files needed..and it will restart ...second time do not press to boot from cd ..and it will ask for the agreement and look for previous installations ...In this moment select to not save anything (esc) and select the C drive hit enter and go for it ...The actually formating of the C drive is made in this moment by selecting to format it in NTFS either quick or normal ..and after that it will start loading windows and keep on ...by following the instruction s..
Good luck ..and pay attention on the boot sequence and the formatting ...
If anything goes wrong ..just take it from the start ..and it will be OK ..
In case you do not use the recovery cd ..make sure you have all drivers stored before you start the procedure ..cause you will need them after the installation is finished..
Jul 05, 2011 | Toshiba Satellite Pro L300 Notebook
My msi a6400 show reboot and select proper boot deviceor insert boot media
This issue appears to be pretty common with the a6400. The message you are receiving is most likely a result of Time Stamp locking the hard drive. The good news is that all of your data is still intact and your computer can easily be unlocked. Please visit the link to MSI's FAQ section for detailed instructions.
Jun 21, 2011 | Computers & Internet
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
Windows logon screen flashes for 6 minutes
After the 6 minutes, what happens? Does Windows finally load? Does it power OFF?
Let's assume Windows eventually does load. The problem wouldn't be the monitor, instead look at your boot devices. You "could" have a USB Flash drive installed on your computer and that may affect the boot process. Try removing any external USB drives from your computer and try booting again. If it does load quicker, you have to check the internal configuration / setup screens on your computer. There is a boot sequence or boot order sequence that needs to be altered.
Mar 09, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
I am having toshiba ppm41e. Boot failure observed, as it seems there is something wrong in the hard disk - either there are cross linked system files or hard disk failure. External CD drive is also not...
Hello cdcrowley2,
it seems that the "problem is the [Operating System] is not loading correctly."
The CPU is trying to find or fix the 'loading' of the OS!
Follow these instructions
  • "To get the Computer to "Boot into the OS and "Loading Windows."
  • Restart the Computer
  • Next, just before the [Page] that you mentioned, "Displays," {Press the F12 'or' F11} button.
  • This will open the "Boot Menu:" [Priority Boot Sequence] window.
  • There will be a "list" of (Devices), Optical Drive / CD, SATA / HardDisk Drive, or USB...
  • "I do not know the "Configuration of your Operating System" or the Drive: that "holds the Boot [NTLDR] files."
  • It may also hold the "Master Boot Record" or Boot.ini file?
  • "So, what you need to do is give the Drives a "Priority Boot Sequence," meaning:
  • "You will 'place' the Drives in the 'order' of [Bootup, First] listings."
  • "You will use the {Arrow buttons} to 'move the "Drives."
  • More than 'likely' it will be the (*Optical Drive / SATA or Hard Disk Drive}.
*Note: "Try each, and hopefully the Computer will make it to "Windows," and you can "Login!"
Recovery Instructions
  • Once the Computer "Bootup!"
  • Quickly press, tap the [F8] key,
  • Located at the top [Middle] of the "Keyboard"
  • The next window will be the "Recovery Environment."
  • "Options:" Select the option, "Repair Your Computer."
  • "Follow 'all' the instructions carefully!"
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution."
Thanks, your 'response' is important!" - paul7of9
Mar 07, 2011 | Toshiba Portege M400-S4032 Notebook
Reboot and select proper boot device or insert boot media in selected boot device and press a key
Hello cdcrowley2, it seems that the "problem is the [Operating System] is not loading correctly." The CPU is trying to find or fix the 'loading' of the OS!
  • Next, just before the [Page] that you mentioned, "Displays," {Press the F12} button.
  • I do not know the "Configuration of your Operating System" or the Drive: that "holds the Boot [NTLDR] files.
  • So, what you need to do is give the Drives a "Priority Boot Sequence," meaning , you will 'place' the Drives in the 'order' of Bootup [First] listings.
  • You will use the {Arrow buttons} to 'move the "Drives."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Feb 27, 2011 | Acer Computers & Internet
Acer am 5630-u5202a boots to Microsoft green bar and then goes to a blank screen. Trying to boot off XP CD receives a PCI.sys error. Trying to boot in safe mode - system stops at a crc.sys file load. What...
This may have happened after an update where a driver was updated that microsoft recommended but was the wrong driver   turn off automatically download and install updates   choose your updates wisely   now to fix that driver either try to roll back the driver   if you can figure out which one it was  even if you have to go to safe mode to do it    or try system restore  to locate system restore choose start/help and support  search for system restore
Nov 03, 2009 | Dell Dimension 2350 PC Desktop
I disabled video card now my monitor is black. i can see the boot screen. i can hear my desktop when it loads. i tried safemode(it never loads in safemode)...last known workig....i still cant see anything.
Kindly repair or reinstall your Operating system. It has a file that has been corrupted. To avoid the damage become big try to repair it or reinstall the OS without reformatting or erasing the files save in your hard disk.
Kindly follow the steps below:
To repair/Reinstall your operating:
1. Insert your CD installer into your DVD/CD Rom then reboot your computer/Laptop.
2. Press F8 or F12 to enable boot sequence and display it in order to select the boot. Then select the DVD/CD Rom boot. Or Press Del to enter CMOS and set the boot configuration sequence and select the DVD/CD Rom as your priority to boot the system.
3. *** soon as message will display "Press any key to boot CD" then press any key to boot CD. Then wait for the CD to load all its components.
4. After loading all its components kindly follow the instructions givien by the installation wizard. Note that if you where ask by the installation wizard to press r to repair or enter kindly select enter then let the system detect the existing installation of OS in your system then it detects then press enter then kindly select "Repair" to repair the detected OS or Select "Don't make changes and make it intact" then enter to reinstall the OS without erasing the files save in your hard drive.
5. Kindly follow the instructions given by the installation wizard to finished the installation or repair of your system OS.
6. If you don't want to repair/reinstall by your self then you can contact a technician expert in computer to fix it for you.
If you need more assistance kindly reply to this post.
thank you
geo_jonas
Jul 30, 2009 | Acer Aspire™ T180 PC Desktop
Error occured while loading a new bin to viewsat xtreme
The operating speed of the processor might be too slow. I am not sure but I think that is the minimum needed to run Xp.
Nov 30, 2007 | Computers & Internet
Toshiba e740 Pocket PC Logo
245 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
