Frigidaire GLEQ2152ES Electric Dryer Logo
Posted on Jul 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer suddently stopped working - Frigidaire GLEQ2152ES Electric Dryer
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Jul 17, 2011
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10844685
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
3helpful
The dryer was working and suddently stop working.I check the fuse in the breaker box and it was okay.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, Hope this helps Please rate me, Thank you
It suddenly stopped working. It is 3 yrs old.
i restore my opperatting sistem and cant access my drivers again
1helpful
2answers
Driver side power window don't word
Replace the window motor...chances are it is burnt out.
1helpful
Dryer won't start
Check the wire leads the motor and make sure they are not burned. I had a dryer do the same thing and the motor lead had burned off the connection lug.
I am getting an error code E0004 on my np8530 copier
there are a motor sensor does not work properly
My dryer won't heat
take the back off and check the heater and thermostates and see if there is coninuity acroos them its your heater or thermostats
hope this helps
Feb 01, 2009 • Dryers
The "Ctrl" stop working
When one key stops working in a Keyboard there is dirt or some other obstruction between the contact layers and the board needs to be dismantled and cleaned or the contact layer has been broken and the keyboard will not respond to that key any more. The first is more likely unless the board has been really abused.
2helpful
3answers
Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
SEE VIDEO
http://www.youtube.com/watch?v=tq3k22cqjR8
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
