Question about Samsung HLP4663W 46" Rear Projection HDTV
Replaced Color Wheel
Hi, I saw that you had your color wheel replaced. When you had it replaced, what all did they have to do? Did they have to change any CCA settings on the TV? I have the CCA settings that came with my new color wheel but have been hesitant to mess with any of them yet. Did he have to pull out a jumper? If so, what exactly does it look like? I'm not seeing it on mine.
    Scholar:
  • 65 Answers
Posted on Sep 04, 2008
Color wheel flashes multiple colors after operating fine for about 7 minutes. Shuts down on it's own and temp/power light blink amber. No heat exhausting from fan. Problem persists.
hi,
You have to check the color wheel of your projector. Every dlp projector have color wheels to provide color. if the rotation of the color wheel is not in corrct RPM this will happen. Also you have to check the color wheel RPM counter sensor. There will be a sensor near the color wheel To count the rotation of the color wheel. First of all you have to remove these two items carefully and clean it well.Then refix it and check. Added the picture of color wheel for your refference.
ok
Jul 27, 2011 | Dell 1409X DLP Projector
Color wheel sounds like a buzz saw. Fan is quiet because there is no noise in the cool-down mode. Can this be replaced by user?
Baily, I have had my HC1500U color wheel replaced two times due to the color wheel's unpleasant "buzz saw" effect showing up every few thousand hours of usage. It is happening again for the third time and I am still within Coscto's warranty so I am going to have it replaced again...will never buy a DLP projector again...too many moving parts that can break!
Would love to be able to replace it myself if you ever find a place that sells the color wheel.
Feb 09, 2010 | Mitsubishi HC1500 DLP Projector
Loud buzzing noise has gotten louder and we know it to be the color wheel as the fan has been replaced. How can we replace the color wheel?
Hire the shop to replaced the colors wheel,because if u replaced,and adjust it wrong,ur power will sutdown.Well cause more problems than same some money.
Jan 15, 2010 | Samsung DLP HL-P5663W 56" TV
TV SAmsung, the picture is bad after color wheel changed
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
Oct 06, 2009 | Samsung Televison & Video
Can someone please tell me the DMD part # for a HLR6167WX/XAP?
When you replace the color wheel on certain models you must remove a jumper plug on the DMD board. There is a service bulletin that is usually included with factory replacement color wheels. If the color wheel has a whine to it that means it is probably used and came out of someone else's set. Anyhow the plug can be accessed as I recall without removing the shield of the DMD board. I know this because my first one of those gave me grief, too. Samsung changed wheels on different versions of the same model tv so it gets confusing. You should be ok though after adding/removing the two pin plastic jumper from the DMD board. The only other thing I saw cause a green picture eas the plug that goes from the DMD to the digital board can develop bad connections and can be replaced with a regular DVI type cable. Hope this helps, Russmann.
May 05, 2009 | Samsung HLN5065W 50" Rear Projection...
Sharp 65dr650 color wheel noise.
I saw the same post, discount-merchant.com sells it for 69.99 but as I found out it is the WRONG one. Not even close and I'm annoyed he obviously never tried it himself. I bought a sharp replacement off of ebay but it died after 2 weeks, no refund. The Samsung model number that does not work is BP96-01579A. Maybe there is a samsung model that works but this was not it.
Mar 26, 2009 | Sharp 56DR650 Television
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Color Wheel
Here's a good article on the Color Wheel
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Samsung HLP4663W 46" Rear Projection HDTV Logo
82 people viewed this question
Henry  Thomas
Henry Thomas
