Hot water in washer comes out fine. Cold water is very slow coming out. It dribbles and takes forever to fill.
  • ejhiemer Mar 19, 2009
    Same problem w/slow cold water. Filter was clean, hose is fine. problem is between hose connection and washer fill mechanism. any ideas?
  • 1,543 Answers
Clean inlet screen where hose attaches to machine. Water from water heater is generally "cleaner" as sediments have had a chance to settle out in the water heater. Cold water carries more stuff directly to the valve screen. Check also for kinked hose.
Posted on Aug 28, 2008
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Water for intial fill works fine . when it goes to rinse cycle the water just dribbles in making wash time go on for ever ! whats the solution?
when you start the washer set it just on cold and see if it fills slowly,when the washer goes to rinse it just uses cold water,you could have a problem with the washer or in the house,when you run it on just cold and if it dribbles in,stop it shut down the water going to the washer,remove the cold water hose from the back of the washer,stick it in the sink or inside the washer and turn it on,if it comes out strong then you have a bad water valve on the washer,if it comes out slowly you have a bad water valve in the house and it's not the washer.hope this helps
Sep 12, 2011 | Washing Machines
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
Problem: the cold water just dribbles out when filling the tank and it takes forever to fill the tub.no problem with the hot water flow.
If you have water pressure to the cold inlet valve and the valve's filter is clear, you probably have a failed inlet valve...Replacing the cold valve should fix the problem..Not a big or expensive job..Good luck....Nomess
May 20, 2010 | Washing Machines
Cold water dribbles in rinse cycle, hot and warm water fine
If you check the warm water flow you'll likely find it is HOT...and not warm. Check the faucet end of hose to see if screen is clogged. Should be screened washer with the dome portion of the screen facing out at you. Remove it and clean with brush to remove grit or scale from screen. If you find nothing there you need to replace the water fill valve located at the other end of the hoses. Good Luck
Aug 23, 2009 | Kenmore 22422 Top Load Washer
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
LG WF-T652A Slow water fill
Probably dirty filters in the inlet part of the washing machine. I had the same problem with this model.
Jul 29, 2008 | Washing Machines
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
